Car stalls out when I put it in gear - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 11th, 11, 08:24 PM Thread Starter
david
Send a message via AIM to kabinet Send a message via MSN to kabinet
Hello!
My car dies in gear! Whacha think it could be? Here's a vid of it dying!
Gimme a list of possible causes so I can go through em. Neighbor thinks I need a new torque converter. I think I just need to tune my carb. Imma test for a vacuum leak tomorrow. What else you think? My carb
My motor
I have a different cam in the motor but i dont know the specs of it.
Turbo 350 trans.
Thanks guys!
kabinet is offline
post #2 of 5 (permalink) Old Mar 11th, 11, 08:48 PM
George
Re: Car stalls out when I put it in gear
if the converter is really tight, possible
more likely bad vacuum leak. retorque the intake expecially the center bolts
Big Cam with low (12) degrees initial timing is also common.
Move the timing to 16 or 18 degs initial, lower the idle speed screw, recheck and adjust.
then adjust idle mix screws
9x out of 10 this will do it
Welcome to Team Camaro!
George Kettler
US ARMY Retired
o 70 Elky SOLD 9/2016
o 68 Vette 427, 4 spd ac owner 25 years
o 68 Camaro Rallye Green Vert 327/2004R/3.73
kettbo is offline
post #3 of 5 (permalink) Old Mar 11th, 11, 10:30 PM Thread Starter
david
Does changing the cam and distributor effect what timing the engine wants? The paperwork said to set spark timing at 32 degrees BTDC at 4000rpm but I have a different cam and distributor than what the engine came with.
snapshot of timing info from the engine specs
kabinet is offline
post #4 of 5 (permalink) Old Mar 14th, 11, 12:47 AM
darrell
check carb-power valve, vacuam leak also chek centrifical weights in dist. whats duration or over lap on cam-possible converter
97Z4C is offline
post #5 of 5 (permalink) Old Mar 15th, 11, 01:58 AM Thread Starter
david
I had a vacuum leak in the line from the transmission. Fixed that and a friend messed with some settings and now it drives! First time its seen road in a year! Yay! Thanks guys!
kabinet is offline
