Bad sending unit? again - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 12th, 11, 07:52 AM Thread Starter
Eric
I just measured the resistance from my fuel sender to ground and got 6.4 ohms and my tank is totally full. It seems like my car is burning them out somehow. That was the second new sender ive put in in the last couple of years. Could my sender wire be shorting out to ground somewhere or what ???
L30 327 is offline
post #2 of 2 (permalink) Old Mar 12th, 11, 09:20 AM
Ted
Re: Bad sending unit? again
What brand sending unit are you getting? Check your wiring all the way back to the sending unit to make sure it is not worn. At full you should be reading 90 ohms. If you get another sending unit go with the spectre unit. They are a little more but are well worth it.
tgifford5 is offline
