305 tpi help - Team Camaro Tech
post #1 of 1 (permalink) Old Mar 22nd, 11, 02:13 PM Thread Starter
305 tpi help
I have a 1986 305 TPI from an 86 Camaro in my truck. Has run great untill Satutday when at GOOD GUYS car show sittting in line it died. Starts back up but would not idle unless you gave it gas, made it home but had to hold accelerator peddle a little to keep it running, ran fine on the highway home but would not idle at stop lights. Once I got home and pulled into garage it worked fine ??? I did notice my inline fuel pump was noisey and the fuel line coming out of the pump was vibrating, I replaced filters a week ago and it ran fine untill this. Could a faulty fuel pump cause it to not idle but run fine on highway or should I check the TPS and IAC sensors. . I have a new fuel pump ordered don't like the intermitent noisy pump. Thanks for the help
labdog is offline
