2003 Speed Sensor - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 23rd, 11, 03:32 AM Thread Starter
Bob
2003 Speed Sensor
I'm having an issue with my 2003 GMC Sierra 4WD. When I apply the brakes at a very low speed the ABS activates. It's my understanding that the speed sensors corrode and need to be 'cleaned-up'. Does that sound like the correct fix for my problem?
I took the truck apart last night and found that the speed sensor is held in by what appears to be a torq-head screw. Is that fastner indeed a torq-head or an allen head screw? What size is it? Any good ideas how I can the screw out without destroying the head? Sure is rusty under that truck!!!!
Thanks for the assistance.
Bob
BOB68396/350 is offline
post #2 of 4 (permalink) Old Mar 23rd, 11, 04:23 AM
Guess
HwyStarJoe's Avatar
Re: Speed Sensor
Well, been down that road a few times now. It's so common.
But I haven't had any luck taking the sensor out of the hub without breaking off the tube part that inserts into the hub. They snap off because they're corroded in there from rust build-up. Then you have to dig the guts out.
If you can get the sensor out in one piece, you can try cleaning up the mounting surface where it screws to the hub, clean the end of the sensor CAREFULLY, and checking inside the hub where the sensor goes for cleanliness. I stuck a magnet down in the hole and rotated the hub a few times.
Twice now I've put it all back together and nothing.... still had the ABS issue. I've been running my truck since November with the ABS fuse removed.
If it's as rusty as you say, go buy a new sensor (or whole new hub with sensor). I can't remember if that screw is a Torx or Allen... probably Torx.
HwyStarJoe is offline
post #3 of 4 (permalink) Old Mar 23rd, 11, 04:32 AM Thread Starter
Bob
Re: 2003 Speed Sensor
Does the ABS dash light go on if the fuse is pulled? Is the fuse inside the cabin or under the hood?
Thanks for your reply!!!
post #4 of 4 (permalink) Old Mar 23rd, 11, 07:47 AM
Guess
HwyStarJoe's Avatar
Under the hood... 60Amp biggy. And yes, I've been staring at both the ABS and Brake lights ever since. But I don't worry about rolling into the garage door or someone's car at an intersection or parking lot anymore.
