1969 RS Headlight Doors - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 23rd, 11, 09:39 AM Thread Starter
Alex
Anyone know why my doors would open when I start the car? The headlight switch is in the off position. I cycle the switch and they do not close. It dose not matter if it is at idle or driving the car, the doors open. I close them manually but when they get vacuum they open. Thanks
dal777 is offline
post #2 of 6 (permalink) Old Mar 23rd, 11, 10:36 AM
Camarodude67
Re: 1969 RS Headlight Doors
I had this happen to me and found the vacuum hose were bypassed next to the headlight switch, so when you turned the car on the headlight would open at startup. So it sounds like the headlight switch may be the problem.
Jeff G.
69 Verts
camarodude67 is offline
post #3 of 6 (permalink) Old Mar 27th, 11, 07:46 PM Thread Starter
Alex
Did they ever work?
Or, did you notice the bypass after troubleshooting to get them working?
Mine have been working fine, then stopped. So I assume nothing is bypassed.
dal777 is offline
post #4 of 6 (permalink) Old Mar 27th, 11, 08:02 PM
Bob
Sounds like possibly a faulty vacuum relay valve. It mounts to the vacuum tank. Could be stuck in the open position. You might also have a hole in the main RS hoses. Somehow,the system is getting vacuum when it should not.
BelAirBob is offline
post #5 of 6 (permalink) Old Mar 29th, 11, 11:20 AM Thread Starter
Alex
Thanks.
dal777 is offline
post #6 of 6 (permalink) Old Mar 29th, 11, 07:06 PM
Gary
Sounds like the EARLY rare daytime running lights option.
69 Camaro convertible 327, TH 350, fully restored, well almost.
Gary Dorion is offline
