How about this one - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 2nd, 11, 12:05 AM Thread Starter
Send a message via AIM to joyride_
How about this one
So my dad's Camaro has roughly 500 or so miles on it...Mallory ignition box with a Mallory unilite distributor. Mallory spiral core spark plug wires that we put together ourselves...kinda a pita...and a voltage spike thingy...here's the link
http://www.summitracing.com/parts/MAA-29351/
thing is...i just pulled the wires off the cap to make some of the nitrous wiring a little easier until i get done and i was gonna put them back on....BUTTTTT...the...connectors inside the spark plug boots were all disintegrating and broke off very, very easily. they were blue and the only one that wasn't like that, was the coil wire. a guy on summits phoneline when i called to order new wires for dad, said it could be due to voltage spikes but we have that spike resistor thing...i'm hoping it wasn't because of poorly put together wires but the guy on the phone said he didn't think so...
any ideas as to what happened? I don't have any pics yet but i can take one tomorrow.
PS : sorry for the several posts the past couple days but can't lie, just got a few questions!
MY RIDE
01 S10 Xtreme 2/3 drop, BUILT 4.3L v6, 5spd
DADS RIDE
69 Camaro 500+ hp 355, t400, currie ford 9inch 4.56 gears, 100 shot
joyride_ is offline
post #2 of 11 (permalink) Old Apr 13th, 11, 03:17 PM Thread Starter
Re: how about this one
So about this...new msd 8.5 spiral core wires, and a new mallory dizzy cap and the thing starts up like a champ.
thing is...why after only 500 or so miles on the new motor, would they completely disintegrate the terminals inside the wires on the distributor cap?
We have a voltage spike thing inline with the distributor and all...we did however put together those old wires ourselves...but i thought i did a pretty decent job putting them together even though they're kinda a pita...lol...
any help would be very much appreciated, as these new wires cost roughly 100 bucks...I'm sure my dad wouldn't like replacing them soon....lol thanks again!
MY RIDE
DADS RIDE
joyride_ is offline
post #3 of 11 (permalink) Old Apr 14th, 11, 10:22 PM
darrell
well--you said you removed them to clean up nitrous--this issue has to be resolved before spraying-not trying to be a ***-but 100 wires verses a engine - gotta have the best quality and set up to spray in my opinion--hope i havent affended anyone
97Z4C is offline
post #4 of 11 (permalink) Old Apr 14th, 11, 11:09 PM Thread Starter
Well no it's fine, those old ones are toast. We just put new ones on, msd 8.5mm super conductor wires...
but i don't know why the mallory ones we only had on for like 500 miles, are toast already..? I'm just trying to figure that part out so we don't waste this 100 dollars on wires we just spent in another 500 miles...
MY RIDE
DADS RIDE
joyride_ is offline
post #5 of 11 (permalink) Old Apr 14th, 11, 11:34 PM
Steiner
Blue and crumbling means heat. Gotta assume that the ends were not assembled properly meaning resistance and heat build up. Were the wire ends folded back over the wire insulation and crimped good so there was good contact against the terminal and wire core? The coil wire was preassembled, correct?
The power filter protects the module itself from spikes.
'69 Camaro
500hp/538lbft
Steiner is offline
post #6 of 11 (permalink) Old Apr 15th, 11, 12:32 AM Thread Starter
Gotcha!! Thank you sir! The wires that were blue and crumbled I for the most part put together myself, but I did fold the wires back and were against the terminal. I don't know what I did wrong to be honest...
You're right though, the coil wire was pre-assembled and was perfectly fine.
The new MSD wires we made sure we're pre-assembled so I guess that's hopefully something we don't have to deal with anymore. The Summit guy mentioned voltage spikes so I had to ask, especially since he said he didn't think our problem was due to poorly put together wires. Now I feel like I owe my dad some money but I'm sure I could put together the wires better than he could....LOL
MY RIDE
DADS RIDE
joyride_ is offline
post #7 of 11 (permalink) Old Apr 17th, 11, 10:07 PM
Re: How about this one
Did you put any dielectric grease in the ends?
400bird is offline
post #8 of 11 (permalink) Old Apr 18th, 11, 06:56 AM
Maurice
this sounds like the culprit.
p.s. adding a bit of dielectric grease to the terminal ends at the cap and plugs is also a good idea. it reduces potential arching ,moisture and corrosion issues and aids in installing plug wires.
BE different....ACT normal.
No one is completely useless..They can always be used as a bad example
68zz502fi is offline
post #9 of 11 (permalink) Old Apr 18th, 11, 09:19 AM
Harry
dawg's Avatar
MSD wires are crap btw!
ill never use them or taylor wires again ever!!!!!
434 stroker
US Navy retired
dawg is offline
post #10 of 11 (permalink) Old Apr 18th, 11, 11:28 AM Thread Starter
We didn't put any grease buttttt we're going to now. lol
What's wrong with MSD wires? I didn't really do any research on them. I know alot of 4.3 guys over in the s10 forum that use Taylor wires and I currently am, haven't had any issues yet..? lol
MY RIDE
DADS RIDE
joyride_ is offline
post #11 of 11 (permalink) Old Apr 18th, 11, 10:20 PM
darrell
the pre made wires should have the lube on the boots--havent hade no problem w msd wires and wouldnt use anything but-
97Z4C is offline
