High-pitched whistle - Team Camaro Tech
post #1 of 14 (permalink) Old Apr 13th, 11, 03:41 PM Thread Starter
ZaCamaro69's Avatar
I recently started noticing a really high-pitched whistle coming from... somewhere? It starts after the car warms up. When I pop the hood, it sounds like it's coming from the carb. But I used the ole mechanic's stethoscope -- thanks, Al! -- and I can't isolate the sound. Listened all around the headers, carb, intake, etc, but nada.
When I turn the power off, you can here the whistle kind of wind down and drop in pitch.
Ideas?
BTW, I found some old posts that indicate the sound's probably coming from carb. As suggested, I tried adjusting the idle, but it didn't change anything. If it matters, I'm running an Edlebrock 600 1406.
ZaCamaro69 is offline
post #2 of 14 (permalink) Old Apr 13th, 11, 04:24 PM
Steve69SS396's Avatar
Re: High-pitched whistle
What are you running for crankcase ventilation?
Steve69SS396 is offline
post #3 of 14 (permalink) Old Apr 13th, 11, 04:55 PM
As Steve suggests, pull the dipstick as soon as you shut the engine off.
Whistle goes away, you need a vented cap on the opposite valve cover.
If the above doesn't give results, look into the vacuum control, cannister, hoses for the A/C and rally headlights mechanism, if equipped.
post #4 of 14 (permalink) Old Apr 13th, 11, 06:36 PM Thread Starter
ZaCamaro69's Avatar
So THAT's what those plugs on the valve covers are for! Always wondered.
Will try that, then explore your suggestions if needed.
Thanks gents!
post #5 of 14 (permalink) Old Apr 13th, 11, 06:39 PM Thread Starter
ZaCamaro69's Avatar
Just to clarify, for certain, that big plug in the valve cover is what vents the crankcase? If that's the case, there's just a big plug there. Doesn't look like it has anything in it that could possibly breath.
post #6 of 14 (permalink) Old Apr 13th, 11, 07:05 PM
Yes, the plug is just an oil fill cap for those valve covers having a tube connected to the OE air cleaner. Otherwise, you should run a vented cap.
post #7 of 14 (permalink) Old Apr 13th, 11, 08:53 PM Thread Starter
ZaCamaro69's Avatar
Ah! In that case, yeah it's connected to the air cleaner... The air cleaner is kind of a rinky-dink set up though, i.e., I think it came off the sale rack at Wally World, and I haven't changed anything on it since purchasing from PO.
post #8 of 14 (permalink) Old Apr 13th, 11, 09:08 PM
Start with the easy things like pulling the PVC valve out while it's running to see if the noise quits instead of pulling the freshly rebuilt TH400 and going through it again cause thats where the noise seems to be coming from....
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #9 of 14 (permalink) Old Apr 13th, 11, 09:46 PM Thread Starter
ZaCamaro69's Avatar
Ron, you sound like a smart man who is speaking from experience! Will try the PCV valve manana and report back.
post #10 of 14 (permalink) Old Apr 14th, 11, 06:02 AM
Edm
Ed
Spray carb cleaner around the base of the carb with the car running. If the idle changes then you have a leak at the carb and its just a matter of pinpointing it.
Edm is offline
post #11 of 14 (permalink) Old Apr 14th, 11, 08:11 AM
A leaky vacuum brake booster will make that exact sound. I know you said its seems to originate from the carb but I would temporarely disconnect the brake booster to rule it out.
67 RS Convertible, 355ci, 650cfm, 5-speed, 12-bolt, 3.90 gears. 12.7 @ 110 mph
Marktat is offline
post #12 of 14 (permalink) Old Apr 14th, 11, 09:23 AM Thread Starter
ZaCamaro69's Avatar
I almost wish this would be the case. THat way I could create an excuse to get rid of the Edlebrock and pick up a Holley.
BTW, that's a bitchin ride you got there. Are those TTII rims in 16"?
post #13 of 14 (permalink) Old Apr 14th, 11, 12:56 PM Thread Starter
ZaCamaro69's Avatar
Y'all were right: it was the PCV. I popped the plug off the passenger side VC and the noise went away immediately. Going to go pick up a breather.
Thanks all!
post #14 of 14 (permalink) Old Apr 15th, 11, 09:48 PM
Edm
Ed
Thanks, good lookin ride yourself. The wheels are 15's. Maybe 16's or 17's after the power tour.
Glad to hear you got the noise fixed, I cannot stand any rattles, ticks or whistles. I have been chasing a small exhaust leak for days now.
Edm is offline
