94 LT1 miss - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 23rd, 11, 01:56 PM Thread Starter
Donni
Question 94 LT1 miss
I just purchased a 94 LT1 Z28-6spd. The car sat all winter and as I pulled it off the trailer to drive the car, it had a fairly decent miss in the engine. As I accelerated through the gears, the miss isn't as bad but the car jerks as I accelerate. I am hoping that it is a bad batch of gas, but could it be more? Has anyone came across the same issue out there? Thanks for the replies.
3rdgenz is offline
post #2 of 6 (permalink) Old Apr 23rd, 11, 07:25 PM
Re: 94 LT1 miss
A gummed up injector or broken plug wire or bad spark plug?
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
Everett#2390 is online now
post #3 of 6 (permalink) Old Apr 23rd, 11, 10:15 PM
Ashlee and Andy
Re: 94 LT1 miss
bad ignition module? on driver's side head. or worn out distributor/ cap may do that also. might want to just start with a tune-up. (Cap- rotor - plugs - wires and pcv)
ap68 is offline
post #4 of 6 (permalink) Old Apr 24th, 11, 07:10 AM Thread Starter
Donni
Re: 94 LT1 miss
Thank you for the replies. I will start with the tune up and will let you know.
3rdgenz is offline
post #5 of 6 (permalink) Old Apr 24th, 11, 02:10 PM
darrell
Re: 94 LT1 miss
i have a 97 with similar problems--it was injectors from setting and drom gas settiing and run thru injectors--also chek egr valve--is ther any codes if so what are the numbers on codes that will lead you to direction--make sure water pump is not leaking cause that will leak on dist. and kill it
97Z4C is offline
post #6 of 6 (permalink) Old Apr 28th, 11, 06:25 PM Thread Starter
Donni
Re: 94 LT1 miss
I just had a diagnostic test done on the car and they told me that the distributor was shot. They quoted me $500 for the distributor and install for OEM. Can I get an aftermarket distributor that will outperform the OEM? I am a big fan of MSD but not sure if you can get MSD for the LT1. Also, if I put a high perf dist. in the car should I upgrade my plugs and wires? Any other quick mods to boost power and limit float?
3rdgenz is offline
