Failed Emissions - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 24th, 11, 11:09 PM Thread Starter
Chris
Failed Emissions
So I went to get my 92 Camaro RS smogged and it passed everything except for the guy said there was a leak in between the EVAP canister and the gas tank. It also smells like fumes in the car sometimes and the idle likes to surge. Please need help
GambitUSMC is offline
post #2 of 7 (permalink) Old Apr 24th, 11, 11:18 PM
Larry
larryh56's Avatar
Re: Failed Emissions
Look for a black plastic canister under the hood with a couple of vacuum lines attached to it. Follow those lines and look for a break in the line under the car and replace the line.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #3 of 7 (permalink) Old Apr 24th, 11, 11:55 PM Thread Starter
Chris
Would that cause the car to fume and surging idle?
post #4 of 7 (permalink) Old Apr 25th, 11, 02:30 AM
parkbrau's Avatar
Yeah, prolly. Take it to the Auto Skills Center, put it on the lift. I take it your at Pendleton.
http://www.mccscp.com/home/Files/pdf...r_Brochure.pdf
parkbrau is offline
post #5 of 7 (permalink) Old Apr 25th, 11, 06:23 AM
Edm
Ed
Nice, I was stationed there in 96-97. Looks like those shops have come a long ways since then.
Edm is offline
post #6 of 7 (permalink) Old Apr 29th, 11, 04:48 PM
When the charcoal canister is bad, it can smell inside the car. Replacing the canister should help. Also, like others have said, check for cracked hoses.
92camarogirl is offline
post #7 of 7 (permalink) Old Apr 29th, 11, 08:33 PM
Hector
Those evap codes are tough... Could be a leak , a bad or loose gas cap... On some it sets if you refuel with the car running.....
If it's not the gas cap you can try looking for a broken evap hose.. If that fails ... I think you need a smoke machine..
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Speedjester is offline
