Engine problems 3.4L Camaro - Team Camaro Tech
post #1 of 8 (permalink) Old May 1st, 11, 11:50 AM Thread Starter
Jan
Hi there!
My camaro makes me crazy. For months I and my dealer try to find the problem.
The problem is the following:
When I start the engine it seems to run very rough (hot or cold makes no difference). A light smell of fuel comes from the exhaust. The spark plugs are black! When I try to drive around it feels like the engine has no power at all. It shakes and backfires all the way. Sometimes the car would not start but when you wait for 10 or 15 minutes it starts! Then mostly runs perfect. But now it always runs that "too rich" way.
My mechanic is convinced that it must be an ignition problem but these parts have been replaced:
- Sparkplugs
- Coils
- Cables
- ICM
- ECM
- EGR (was leaking)
- Camshaft sensor
- MAP sensor
- Catalytic converter
Fuel pressure seems ok (40PSI) and there seems not to be a vacuum leak (tested with startpilot).
I read the codes, no ones were stored. The BLM and INT values told me that the engine runs WAY to rich! The values were around 100 / 110 !!!
Does anyone have another idea what could cause this problem??
sateng is offline
post #2 of 8 (permalink) Old May 1st, 11, 01:04 PM
George
Re: Engine problems 3.4L Camaro
You didn't specify - carburated or injected, but I would assume injected if you're checking fuel pressures. Have you run injector cleaner through it, and did that change anything? You also may have an exhaust restriction (plugged catalytic convertor - if equipped) causing excessive back pressures, if the engine doesn't want to run up too speed.
67 RS Ragtop is offline
post #3 of 8 (permalink) Old May 1st, 11, 01:07 PM Thread Starter
Jan
Oh I'm sorry - sure it is an injected engine. I tried to clean the injectors with injector cleaner and my mechanic also did a cleanup with the help of a computer...no change
What I also forgot to mention: The problem exists on ALL cylinders the same time!!! When the engine runs fine, all plugs are lightly brown, when it runs like crap all plugs are black.
Chevrolet Camaro 3.4L SFI 1993
sateng is offline
post #4 of 8 (permalink) Old May 1st, 11, 04:15 PM
Dan Ensign
I think you have a bad injector that is intermittenly shorting and taking the rest down with it. saw this on a 92 IROC-Z with a 5.7l in it. Good luck.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #5 of 8 (permalink) Old May 2nd, 11, 11:16 AM Thread Starter
Jan
okay... told my mechanic today to disassemble the intake to measure the injectors resistance etc.
will have a result in the next days, then will post it immediately
sateng is offline
post #6 of 8 (permalink) Old May 3rd, 11, 10:59 PM
darrell
better check the fuel regulator too--and make sure its not getting fuel on vacuam port of regulator
97Z4C is offline
post #7 of 8 (permalink) Old May 3rd, 11, 11:05 PM Thread Starter
Jan
I think the regulator is fine. Pressure-tested it at the schrader valve before the regulator and there were the 40PSI pressure.
There is no fuel / fuel odor from the vacuum port.
When I ran the engine and disconnected this vaccum port the engine was sawing, reconnected the vacuum line and then it ran but like before....
sateng is offline
post #8 of 8 (permalink) Old Aug 20th, 11, 01:20 PM Thread Starter
Jan
Smile Re: Engine problems 3.4L Camaro
very much time went on but now the engine runs fine again!!!!
PROBLEM SOLVED
It was the injectors causing this trouble!
Thanks to all who helped me
sateng is offline
