Gassed out - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 24th, 02, 06:16 AM Thread Starter
I get alot of exaust and gas fumes coming in to the car when the windows are cracked open or further,I replaced the trunk seal which was in bad shape , this helped some still have problem. I checked for exhuast leaks its all good. The tail pipes exit out the back almost as stock, there cut a little closer to the car.The wife does not like to drive in the car for this reason,anyone please help
67az.ss is offline
post #2 of 3 (permalink) Old Jan 24th, 02, 07:09 AM
Send a message via AIM to Spames
You don't have a gas leak under the hood, do you? Sounds like it is coming from the engine bay.
Are you running a PCV valve? I've heard that using one can reduce fumes.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #3 of 3 (permalink) Old Jan 24th, 02, 07:12 AM
DjD
DjD's Avatar
If I don't put the gas cap on right on my '69 the same thing happens!! Well not exhaust but gas fumes..
...Dennis
"The '69, the '96 & the club"
DjD is offline
