popping - Team Camaro Tech
post #1 of 5 (permalink) Old May 16th, 11, 03:38 AM Thread Starter
dave
popping
popping out the rightside only,pulled plugs black but gap correct. thighten the header bolts
dave67707385 is offline
post #2 of 5 (permalink) Old May 16th, 11, 06:18 AM
Camarodude67
Re: popping
Hi Dave, could be anything, points setup, is engine a new build or did you just do tune up, need more info here....
Tell us about the complete setup and any changes that you did if any?
Jeff
69 Verts
69 Z/28
camarodude67 is offline
post #3 of 5 (permalink) Old May 16th, 11, 10:46 AM
darrell
Re: popping
yep--a little more info--chek to see if plu wires have burnt spot or arcing--is all the plugs black on that side or other side--maybe leaking ventures on carb
97Z4C is offline
post #4 of 5 (permalink) Old May 17th, 11, 02:01 AM
Re: popping
Start the engine cold. Let it run for 30 seconds or so, then shut it off. Check for a cold header tube. If one is cold, investigate that cyl. Likely a fouled plug, plug wire, etc.
BPOS is offline
post #5 of 5 (permalink) Old May 17th, 11, 08:16 PM
Wes
Re: popping
First thing I'd look for is a vacuum leak.
Straight-line-69 is offline
