H.E.I. Distributor ? - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 3rd, 03, 01:24 PM Thread Starter
Hey guys, I have a question on my HEI distributor. I recently took it out and rebuilt it. My question was is it possible to be off a tooth or so when installing the distributor? The reason I ask is that I installed my distributor with the piston 1 on TDC on the compression, or fire stroke. I also set the distributor shaft that comes out of the oil pump with the notch pointing to cylinder 5. Anyhow the car started up fine, and I set timing at 8 degrees btdc required by comp cams. I did notice though that one of my hoses going to the vacuum advance can ,barely hooking up . The hose seems to have shortened, but i did not cut the hose or anything. The car runs good and sounds fine. Thanks a lot.
peters76 is offline
post #2 of 6 (permalink) Old Feb 3rd, 03, 06:32 PM
Matt Jones
It is possible, yes, but usually you'll notice by the different phasing (distributor turned to a different direction than usual).
Matt Jones
1969 Base Camaro
Vortec 355, Perf. RPM, Demon Carb., TH-400
All sheetmetal is NOS GM
See my UPDATED webpage at: http://www.geocities.com/compuboy007/ (Updated: 1/13/03)
Silver69Camaro is offline
post #3 of 6 (permalink) Old Feb 3rd, 03, 07:54 PM Thread Starter
I think that is what happened. My distributor is about 1 to 2 inches out of place from where it was I think anyways. I had marks on the firewall and distributor. Anyhow can this affect timing etc. My car seems to be running fine. Initially I did hear a backfire through the exhaust, but that was because my timing was below 8 degrees. Once at 8 degrees it was ok.
peters76 is offline
post #4 of 6 (permalink) Old Feb 3rd, 03, 09:57 PM
if the timing shows correct with the light, then it's correct. if it bugs you, you can lift the distributor up until the teeth disengage and turn the rotor while pushing it back down and move it a tooth (with the engine off, of course)and then use a timing light to reset the timing.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see dirty pics here of a car that gets driven http://community.webshots.com/user/novaderrik
novaderrik is offline
post #5 of 6 (permalink) Old Feb 4th, 03, 04:03 PM Thread Starter
Yes, my timing does set up at 8 degrees below tdc. And it runs fine, I just thought it was wierd how the distributor set up in a different location, and still ran. Thanks for the help guys.
peters76 is offline
post #6 of 6 (permalink) Old Feb 5th, 03, 10:39 AM
robert
rolling-robert's Avatar
heres something i learned from my dad:
"If it isnt broke, dont try to fix it"
in other words: it runs fine so keep it that way
rolling-robert is offline
