fuel pump? - Team Camaro Tech
post #1 of 5 (permalink) Old May 25th, 11, 04:31 PM Thread Starter
Big daddy
fuel pump?
Hello guys,what are the symtoms of pump failure.I havn't had a failure of on in years.Here is what I have.car will start and idle good and put in neutral a reve good.The minute let clutch go and put power to the wheels,it stutters and bucks,if I peddle it,it will catch and run good,then breakup again.Have checked timing the whole nine.What else can I do?
67ssclone 383 4spd 3.73 vintageair
carhodge is offline
post #2 of 5 (permalink) Old May 26th, 11, 03:59 AM
darrell
Re: fuel pump?
sounds like maybe carb issues-what carb u running--if qjet-sounds like power valve is stuck in down position--u can fill the vent on carb with fuel( if you put too much it will run out of ventures into motor-disconnect fuel line to carb and put fuel pressure gauge on it -start car and see what pressure you have--you can also try this without putting fuel in carb needs 5lbs of pressure--have you checked the fuel filter in carb -have this carb been setting for awhile
97Z4C is offline
post #3 of 5 (permalink) Old May 26th, 11, 04:04 AM
darrell
Re: fuel pump?
if fuel pressure is good--filter is good and its a qjet oem carb-chek power valve in carb-u can do this by taking a small flat head screw driver a placing it in vent of carb -gently push screw driver -should feel the spring loaded power valve go up and down if not its stuck in down position and need to overhaul carb
97Z4C is offline
post #4 of 5 (permalink) Old May 26th, 11, 03:42 PM
Steven
Re: fuel pump?
Seems like you are breaking up once car is under load ... I wander if the advance is working properly. i would revisit the distributor and make sure that everything is working properly.
sdtsdt is offline
post #5 of 5 (permalink) Old May 26th, 11, 10:03 PM Thread Starter
Big daddy
Re: fuel pump?
Will try advance and carb,running 750 holley.
carhodge is offline
