skipping - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 22nd, 03, 10:00 AM Thread Starter
Red face
my 78 camaro is skipping really bad i just put new plugs,new coil and a new wires. i was just wondering if anybody knew wht could be wrong with it
hotrod78 is offline
post #2 of 6 (permalink) Old Feb 22nd, 03, 02:11 PM
Chad
67 Plum's Avatar
Check for a vacume leak on the port on the #5 & 8 intake runner.
67 Plum is offline
post #3 of 6 (permalink) Old Feb 23rd, 03, 05:19 AM
TRT
Was it "skipping" before you did the work ?
The voice of dissent
TRT is offline
post #4 of 6 (permalink) Old Feb 23rd, 03, 03:37 PM Thread Starter
no it was not
hotrod78 is offline
post #5 of 6 (permalink) Old Feb 24th, 03, 06:05 PM
Some spark plug wires specificly the solid wire type aren't going to be transfering the volts right down the wire with big volts coils. One of the ignition manufacturers has a trouble shooting section that would help.
Normally it's called missing not skipping. You skip class and the engine misses. Easy to remember when spring comes around.
Snatchin'gears is offline
post #6 of 6 (permalink) Old Feb 24th, 03, 06:17 PM
Steven
When installing you new plugs you have to be careful that the area around the spark plug hole is clean. If there is gunk, then you can pick that up when you are trying to line up the plug and if you get enough greasy dirt packed onto around the electrode, it can prevent the plug from firing. Also, if you did not do the plugs one-by-one, you need to make sure that you do not have any wires on the wrong plugs. Lastly, make sure that the plug wire is all the way on, fully pushed over, sort of snapping on the end of the plugs. Hopefully, you didn't damage any wires when you removed them, did you. You can't just grab the wire and pull it. You have to work the boot off of the plug ... BTW, why do you say "a new wire " ? DId you only replace one spark plug wire, or, was this a wire to something else ?
sdtsdt is offline
