Service engine light soon light flashes - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 20th, 01, 04:54 PM Thread Starter
Talking
I have a 97 rs with about 49,000 miles on it. Right after i filled up with gas last week, the car started to hesitate and almost stall, also the service engine light soon light came on. If i hit the gas the light will start flashing then go solid after i take my foot off the gas. Owners manual says it is a Fuel/air mixture problem, i have no idea how to fix this problem.
Anyone have any suggestions.
jrich10 is offline
post #2 of 9 (permalink) Old Dec 20th, 01, 05:29 PM
Cool
Sounds like it could be your O2 sensor it feeds your ECM information on the exhaust content wether the car is running lean or rich. Its about a $40 part. ITs screwed into your exhaust pipe around the manifold or cat. conv.Pretty easy to replace just unplug and unscrew. There are several possibilities including the prom or chip but this is the most common thing I have found.
Randy Davidson is offline
post #3 of 9 (permalink) Old Dec 20th, 01, 06:24 PM
Joe
Try to tighten your gas cap first. OBII computers run a vacuum check on the evap system every time you start the car. If the cap is loose it will set the engine light. Also if the cap is loose enough it can make the car bad.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #4 of 9 (permalink) Old Dec 20th, 01, 07:27 PM
Hey Randy there are no more chips.1996 and above are obd11 and have electronically erasable computers that can only be programmed by another computer.Anyway if the check engine light flashes on and off on a obd11 vehicle it means emissions are so extreme that possible damage 'will' occur to catalytic convertor if the problem is not fixed."usually" this is misfiring that pumps raw unburned gas out exhaust overheating the convertor.Have it checked out and don't start replacing a bunch of parts.
sschevyfan is offline
post #5 of 9 (permalink) Old Dec 21st, 01, 01:17 PM Thread Starter
[Is this related to the EVAP canister? Book says that it could be bad. It is i believe mounted in front od the back left wheel
jrich10 is offline
post #6 of 9 (permalink) Old Dec 21st, 01, 02:16 PM
take it somewhere and get it looked at by a reputable mechanic so you don't spend money on unecessarily. If it is emmissions related, it may be under warranty.
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
If you have no fear, you're not going as fast as you could.
chev64 is offline
post #7 of 9 (permalink) Old Dec 23rd, 01, 03:51 PM
Yeah, flashing service engine soon light indicates a misfire condition. Since this happened right after you got gas, I'd guess that you somehow got a batch of bad gas.
Justin Traunero
[email protected]
-1967 Camaro SS350 clone
My 1967 Camaro
jrt67ss350 is offline
post #8 of 9 (permalink) Old Dec 25th, 01, 05:10 AM
no , its the gas cap, tighten it down. at least make sure it clicks a few times... as said previously, the obd2 system (not obd-11 (thats a future computer after obd10) runs a system test that tests for fuel pressure and vacuume. if it finds a drop in tank pressure , it will trigger a "service engine soon" code...
I've never had "bad gas" in my life. (well except for that 1 egg salad sandwich) hehehehe
Chris's 67 RS 327,can be seen at http://www.67rs.com
check out another site once in a while! http://www.fbodyconnection.com
[This message has been edited by Chris Edwards (edited 12-25-2001).]
Chris Edwards is offline
post #9 of 9 (permalink) Old Dec 25th, 01, 06:51 AM
Yeah Chris I should have put in the number 2 instead of trying to make it look like the roman numeral '11'(2) like it's usually written.I think & hope everyone got the idea.
I'm not sure the check engine light would flash because the gas cap was loose but it would for sure make the light come on steady.I still think it's from misfiring.
