Engine is missing. - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 26th, 02, 06:11 PM Thread Starter
I have a 1992 Camaro RS, with the 3.1 liter engine (yes I wish it was a 350, but oh well). My problem is that when I push in on the gas the car doesn't go very much. It has a huge miss or something. If anyone could help me figure this one out I would greatly appreciate it.
Thanks,
[email protected]
Steve6523 is offline
post #2 of 3 (permalink) Old Jun 26th, 02, 07:01 PM
Plug it into a diagnostic scanner and see if you get any codes or youcan ground the diagnostic terminal and count the check engine light flashes. It sounds like a bad throttle position sensor, but the only way to be sure is to have it checked out.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 3 (permalink) Old Jun 27th, 02, 05:41 PM
Most likely plug wires.My daughter has a 95 V6 and it's went thru 2 sets in 5 yrs.Have a friend look under the hood at night with the car in gear slightly power braking it.It should look like a spark show,usually at or near the plugs.If this does not work out,for sure do what the other post says and take it to a shop.Good Luck..
69 Camaro SS 350 4 speed
71 Nova
gene stills is offline
