problem vibration - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 18th, 01, 06:30 AM Thread Starter
Angry
1992 camaro w/305 vibrates beyond exception.It used to vibrate on deceleration at speeds above 50 so I put a rear end in and now I have a similiar problem but worse.It vibrates on acceleration and deceleration at speeds above 45mph.Is there some sort of adjustment to conquer this?Please help I am throwing tools and cannot cope with this!
gmcie2001 is offline
post #2 of 3 (permalink) Old Feb 18th, 01, 06:52 AM
JohnZ's Avatar
Sounds like a prop shaft out of balance - check to see if it has thrown a welded-on balance weight or has been dented or damaged; could also be a U-joint starting to freeze up (I assume you have already verified that it's not a tire balance problem).
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #3 of 3 (permalink) Old Feb 18th, 01, 07:27 AM Thread Starter
Ive eliminated the U joint as a suspect.Are those propeller shafts balanced and how would I check?Also could it be the drive angle?Is this adjustable
[This message has been edited by gmcie2001 (edited 02-18-2001).]
