BBchevy noise in upper end - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 26th, 01, 02:23 PM Thread Starter
my 468 motor has less than 3000 mi.
and i'm getting a intermitting noise under valve cover on pass side sounds like loose rocker but it comes and go's when i pulled the cover all is well???
SY-1 is offline
post #2 of 2 (permalink) Old Dec 26th, 01, 04:56 PM
Jody
camcojb's Avatar
A couple of things to check are a worn rocker arm and/or worn valve tips. I've also heard a loose guide can make an erratic ticking noise. A worn or damaged lifter would do the same thing.
Jody
camcojb is offline
