starting problem, bad flywheel ??? - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 3rd, 11, 07:09 PM Thread Starter
DT
Donny
DT's Avatar
Hey guys, I'm having a problem starting my car now after the top half of the motor was done. New heads, rockers, cam and lifters etc. The starter makes a terrible clunk and is unable to turn the engine. I'm afraid to keep trying to start it now. The starter is brand new. It acts like a compression stroke symptom if you know what I mean. Wonder if the teeth on my flywheel is NG ?? Any ideas??? Thanks
DT is offline
post #2 of 4 (permalink) Old Jun 3rd, 11, 07:22 PM
Steven
stamatisg1977's Avatar
Re: starting problem, bad flywheel ???
take a marker and mark your balancer/pulley and put another mark on the block in relation to the one on the balancer/pulley. take a socket, put the tranny in neutral and turn the crankshaft about a 1/4 of a turn. then turn the key to try starting the car. if the same thing happens and the marks you made on the engine and balancer line up or are very close, you may have broken some teeth off the flywheel.
another way is to take the starter off and look into the opening and have a buddy turn the crank with a socket as you inspect the flywheel as it is turning.
good luck
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 4 (permalink) Old Jun 3rd, 11, 07:52 PM Thread Starter
DT
Donny
DT's Avatar
Thanks Steve. I figured out my problem. I had the distributor advanced to much. Duh.... LOL
DT is offline
post #4 of 4 (permalink) Old Jun 3rd, 11, 08:17 PM
Steven
haha glad it was an easy inexpensive fix!!!
Tremec TKO 600
