car wont start after plugs changed - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 6th, 01, 03:40 PM Thread Starter
Angry
i cganged my plugs and now my car wont start i have a 1994 z28 350 i did a spark test plenty of spark the car ran fine but now its just keeps turning and wont start
post #2 of 6 (permalink) Old Apr 6th, 01, 04:24 PM
Are you sure you got all the wires back onto the opti in the correct order? Is the coil plugged in? did you unplug any other sensors to gain access to the plugs? Is there a vacuum leak by the air intake pipe? Are you getting fuel pressure?
check all these things and let us know. I have the same engine in my 68, but have never had that problem before.
Tyler
<A HREF="http://www.pro-touring.com/featured_cars/tyler_beauregards_68_camaro/tyler_beauregard.htm" TARGET=_blank>
68-LT1-T56
</A>
Teetoe_Jones is offline
post #3 of 6 (permalink) Old Apr 9th, 01, 04:41 PM
sounds to me like you just F'd up the firing order.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING! http://nav.webring.yahoo.com/hub?ring=camaronet&list
[This message has been edited by Chris Edwards (edited 04-09-2001).]
Chris Edwards is offline
post #4 of 6 (permalink) Old Apr 14th, 01, 03:56 AM
I know this sounds dumb, but did you put your Distributer in 180 deg off. My buddy did that and it was a real pain to figure out what he did. Also I would check to see if the dist. cap is on correct. You also might have your timing way off. At TDC the rotor should point to you #1 cylinder spark plug wire, (not the actual cyclinder). I have heard of people getting that confused. Good luck
Blk69 is offline
post #5 of 6 (permalink) Old Apr 14th, 01, 07:09 PM Thread Starter
Talking
thanks for all the respnces but i did the lugs right my feul pump was bad had to change it and car is working great now i am now running my 9.9 sec 1/4 mile again ty
post #6 of 6 (permalink) Old Apr 14th, 01, 08:39 PM
Dale
WOW,now that's quick,betcha still gets 17+ miles per gallon too!
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
