edelbrock idle answer - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 17th, 01, 01:14 PM Thread Starter
Joekool came closest to figuring out what was wrong with my carb. He noticed that the problem seemed to be associated with one plane of the intake manifold. I changed plugs and leaned down that idle screw to no avail. It was still missing badly on 1,4,6,and 7 and the idle screw on that side wouldn't adjust. I took the primary venturi boosters out and found some trash in the small brass tube on the bottom of the booster on the side of the carb I was having trouble with. Cleaned it out and she now purrs like a kitten. Joekool spotted an important clue and made me concentrate my efforts on that one side of the carb. One hole, actually, the drivers side primary. Thanks, Joe.
Farmer
Terry Farmer is offline
post #2 of 3 (permalink) Old Nov 17th, 01, 01:30 PM
DjD
DjD's Avatar
Terry, that's good to hear. Could you cut and paste this into the orig thread so when forum clean up occurs the solution will be with the problem. We look to save good information but only when the thread is complete start to finish.
Thanks,
DjD is offline
post #3 of 3 (permalink) Old Nov 17th, 01, 06:35 PM Thread Starter
Done. All of the pertinent info is now in "edelbrock idle problem". Thanks for this great forum. It certainly helped me!
Terry Farmer
Thanks,[/B][/QUOTE]
