Hard time putting gas in the car - Team Camaro Tech
post #1 of 13 (permalink) Old Jun 11th, 11, 08:47 AM Thread Starter
Hi all,
I have a question about filling the tank on my 68 camaro. When i try to fill it the gas spits out all over the place. It has a new tank and sending unit. Could it be the filler neck? There are no kinks in the filler.
Thanks,
MickeyPriz is offline
post #2 of 13 (permalink) Old Jun 11th, 11, 08:53 AM
Bill
Calpantera's Avatar
Re: Hard time putting gas in the car
Did you have this issue before the new tank Mike? How are you filling it? Just putting the nozzle in as far as it will go and pull the lever all the way back or? I personally hold the collar of the nozzle with my hand and pull the lever back about half way. Then I "listen" for it to get full instead of letting the nozzle shut off by itself.
Calpantera is offline
post #3 of 13 (permalink) Old Jun 11th, 11, 09:01 AM Thread Starter
Yes i had this issue prior. I hold the nozzle about half way in and pump it slow. Ive tried a couple different ways and nothing seems to work. So its hard trying to get the tank full. About every 2 gallons it seems it wants to spit the gas out.
post #4 of 13 (permalink) Old Jun 11th, 11, 11:28 AM
Gary
This happens to me from time to time too. Repo tank and sending unit. I find holding the handle at about 9:00 and pulling the lever back about half way works best.
Gary
Gar's67 is offline
post #5 of 13 (permalink) Old Jun 11th, 11, 11:50 AM
Mike I have the same problem. I just think it's today's nozzles. I turn the nozzle sideways, don't put it all the way in the car and then pump slowly. It's a pain but saves a big mess.
SB 406/700r4/3.55 posi/Hotchkis Stage 2 TVS/Delphi 600 Series PS Box/Holley Terminator EFI
Andrew68 is offline
post #6 of 13 (permalink) Old Jun 11th, 11, 11:52 AM Thread Starter
Thanks guys. Ill try that.
post #7 of 13 (permalink) Old Jun 11th, 11, 12:19 PM
Yes, it is an issue with design of the old filler style and new gas pump nozzles. If you have ever seen an old, leaded fuel dispenser, the tube diameter is significantly larger, and most were relatively less curved. In fact, when unleaded came into being, the nozzles and the filler neck openings were specifically made smaller, so folks wouldn't put leaded gas into a car that required unleaded.
67-68 are hard to fill with a modern filler, particularly those with the vapor recovery system that requires the collar to be pushed back before the pump will send fuel. 69's have an issue because, although the filler is behind the plate, it has a little less curve and is easy to overfill too.
The best way I can explain to someone who is not used to fueling an older car like ours is to bend over and listen to the change in tone as the tank becomes close to full, and then really throttle back on the trigger. Once you have done it a few times, you will know what I am talking about. When I used to fill either my 67 in HS (mid-1980s) or my 68, I had an old towel in the trunk to put under the filler opening to catch any drips. If the station has a window wash station, the blue paper towels work nicely for that too.
Either way, you have to pay attention when filling our old cars. Locking the trigger and letting the fuel fly is a recipe for around a quart of overfill on the tail panel, bumper, and ground
Eric
Eric Kammerer is offline
post #8 of 13 (permalink) Old Jun 11th, 11, 12:45 PM Thread Starter
Thanks Eric. Thats what i have been doing. Ill deal with the slow process or keep my ohm meter connected the the sending unit wire....
post #9 of 13 (permalink) Old Jun 11th, 11, 02:29 PM
mark
this problem is why I can't belive someone has not came up with a kit so you open your trunk lid and fill your tank from there. splice into the filler tube right there. I am not any good at fabricating but I would think someone would come up with something. mark
stroud6 is offline
post #10 of 13 (permalink) Old Jun 11th, 11, 02:45 PM
I wonder if this thing designed for motorcycles would work to prevent this.
http://www.mccuff.com/
1969 Camaro SS
350/300 M20
12 Bolt 3:73 Posi
Myfirst 69SS is offline
post #11 of 13 (permalink) Old Jun 11th, 11, 04:41 PM
First, here is a thread on this very same subject, where someone discussed using the McCuff... https://www.camaros.net/forums/showthread.php?p=1245518
Also. it would be fairly easy to just locate the fill inside the trunk on a 67-68, like some street rods do, as long as the fill cap is NOT vented and that the tank itself is vented outside the car. I would never consider it, but I have filled so many of these old cars I don't have a problem with the location as GM intended. Having a fill port inside the trunk on a car that actually gets driven doesn't seem like a good idea...
http://66.154.44.164/forum/showthread.php?t=373183
Eric
post #12 of 13 (permalink) Old Jun 13th, 11, 02:01 AM
darrell
the older tanks dont have the vent tube in the neck and when you put a larger filler head at the pumps-there is not enough vent
97Z4C is offline
post #13 of 13 (permalink) Old Jul 7th, 11, 09:14 PM
gas in tank is hot, gas in pump is cold. when cold hits hot, make a vapor fog that blows out the filler tube due to the nozel of today being smaller. after you get a little gas in the tank, a gallon or so, it should work normal. also good point to have nozzel at an angle, preventing the vapor from spewing out. and coold down quicker . if this is so, put fuel in when the car is cool and see if it does the same. tks good luck
mikess68 is offline
