Surging at wide open throttle - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 12th, 11, 12:06 PM Thread Starter
kris
hello everyone, i have a 67 camaro with a 30 over 350, th 350 ,edelbrock intake and edelbrock 1406 carb.hei dist. cars runs awesome at idle, and at cruising speeds. when i am cruising at 45 and floor it, it kicks down to a lower gear and goes great but then it starts surging at higher speeds like its starving for fuel. if i let up a little bit its fine, just cant keep my foot in it or it will surge. any ideas? is there a metering rod in the power circuit to allow more fuel at wot? thank you..kris
cookkr is offline
post #2 of 8 (permalink) Old Jun 12th, 11, 01:17 PM
Harry
dawg's Avatar
Re: Surging at wide open throttle
might be an ignition miss!
90 % of the time a surge is an ignition miss.
check wires and cap/rotor.
plz tell me your not using taylor wires!
they are pretty but dont last long.
434 stroker
US Navy retired
dawg is offline
post #3 of 8 (permalink) Old Jun 12th, 11, 01:45 PM
DjD
DjD's Avatar
Surging is a sign of a lean condition.
...Dennis
DjD is offline
post #4 of 8 (permalink) Old Jun 12th, 11, 01:56 PM
Steps
yep souns as if leaning out....I know nothing about edelbrock carbs, but sounds like bowl level, and/or fuel delevery....eg blockage of crap in filters/lines
Steptoe is offline
post #5 of 8 (permalink) Old Jun 12th, 11, 04:46 PM
Hows your fuel pressure and pump ?
68 Camaro~LSx ~all motor
post #6 of 8 (permalink) Old Jun 12th, 11, 05:13 PM Thread Starter
kris
pressure is good and fuel pump is new. thank you for all of your replies. i think i will contact edelbrock and see if there is any kits i can buy for the secondaries. the float level is good as well..
cookkr is offline
post #7 of 8 (permalink) Old Jun 19th, 11, 04:04 PM
Wes
What he said. Could be a vacuum leak or a carb that needs to be rebuilt or recalibrated (enrichened).
Straight-line-69 is offline
post #8 of 8 (permalink) Old Jun 20th, 11, 10:51 AM Thread Starter
kris
update: i went 2 steps richer by getting new metering rods.. what a difference!!!!!
thank you for everyones replies!!!
cookkr is offline
