4speed - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 2nd, 03, 06:05 PM Thread Starter
i recently bought a 69 camaro with a 4 speed not sure if it is a which muncie it is anyway i wanted to change the fluid to red line manual tranny fluid after looking tranny over could not determine how to drain old fluid only found one plug about a quater of the way up on left side of tranny ? thanks for any help
CRAZYRS is offline
post #2 of 5 (permalink) Old Apr 3rd, 03, 10:21 AM
If it's an original Muncie, the bottom bolt holding the two halves to the center section is drilled all the way through. Pull this bolt and the fill plug and go have a couple cool ones.
tloleson is offline
post #3 of 5 (permalink) Old Apr 3rd, 03, 04:41 PM Thread Starter
CRAZYRS is offline
post #4 of 5 (permalink) Old Apr 4th, 03, 03:08 PM
I believe only the Muncie M22 had a drain plug, the normal Muncie m-20 & M-21 drain holes were not drilled and tapped. If you want to change the oil you'll need to drill out the aluminum plug & tap it. Its on the passenger side, the alternative is to use a vacuum pump & suck out the old oil thru the fill plug u mentioned.
billyd is offline
post #5 of 5 (permalink) Old Apr 4th, 03, 04:22 PM
I told a guy doing my exhaust I didn't have the M22 and mine is a M20 when he said he has the same transmission. The darn thing has a drain plug on the bottom but no real loud whine. Who can tell with the loud exhaust though. I thought the M22 had some ribs on it's case?
Snatchin'gears is offline
