keepin alive old racecar - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 13th, 11, 01:40 PM Thread Starter
Robert
I have a 1989 Iroc it was a IMSA racecar from the Firestone Firehawk series. it has a 305 that is built to their specs for that year. my problem is I needed a new feul pump so I put one in. And I had a hole in the smog tube off of the exhaust manifold. I took it off and pluged the exhaust. I did put new spark plugs and coil and distributer cap on. I still missing mass air senser. How ever before I did this work and before my fuel pump went out they car would do burnouts like it was on ice. Now they car fires up with no problems and revs up like there is no problem. It will drive but is very sluggish and will not even turn over the tires anymore. I think it might be a vccume somewhere but I am not a good enough mechanic to figure this out. I didnt have a mass air senser when I bought the car it has always been a racecar and ther is no catalac converter on it the exhaust is a 2 into 1 tailpipe. If anybody has any pictures or ideas on the smog tubes and vaccum pump. the vaccume pump did go into the smog tube does this affect it.
Thanks everybody I am in a need for a crew cheif to keep the old racecar alive.
[email protected]
robjohnson is offline
post #2 of 5 (permalink) Old Jun 13th, 11, 11:06 PM
darrell
Re: keepin alive old racecar
plugging smog tube aint your problem--vacuam leak maybe--cant hear one-maybe spray alittle brake clean around to find it--you will notice idle change if you hit it--i think those have 2 plugs to dist-wiring prongs-if you leave 1 of those disconnect-it will not have any timing advance-or it might be a connector on main wire loom disconnected--read how to set timing and see if it is where it should be on radiator shroud
97Z4C is offline
post #3 of 5 (permalink) Old Jun 14th, 11, 04:29 AM
Retrace your steps from beginning to the last and maybe something will pop up. Go through the motions and you'll see it.
As Darrell suggests, holes in the smog tube was not your problem, or did you introduce a problem?
Doing a good job is like peeing in your dark pants you get a warm feeling, but nobody notices
Everett#2390 is online now
post #4 of 5 (permalink) Old Jun 14th, 11, 11:44 AM Thread Starter
Robert
I didint think it was the smog tubes, but the reason I was wondering if it could be part of the problem is because the vaccum pump hooks up to the smog tube. On my vaccume pump i have a 1/4 inch line that hooks up to the smog tube and one a little bigger that I don't know where it goes. one sucks and the other blows. So I pluged them up it ran the same wheather they were pluged or not. I checked all the connecters to the distributor and they are fine. Would my timming get thrown off by just changing the cap, coil and wires and feul pump. My feul pressure is around 45 to 47 psi I have a pressure guage hooked up in the car. I will read up on setting my timming. This car is in really clean shape and I have aoriginal Bilmar Raceing engine in it. When my feul pump went out I put another intank high pressure fuel pump. Ihave been told that is good pressure my son said he read it was sapose to be 15 psi that sounnds way to low.
Thanks for all of your time.
Rob
post #5 of 5 (permalink) Old Jun 14th, 11, 08:39 PM
darrell
that is not a vacuam pump--that is a air pump for your emissions-way of recycling un burnt fuel--if you got a belt on it-you cant plug in and out of pump with belt on-will be major drag and burn up-i still would chek timing its part of a tune up
97Z4C is offline
