exhaust fumes - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 16th, 11, 09:32 PM Thread Starter
rara51
exhaust fumes
hi all, got me a 68 camaro and just have one quick question. my garage is enclosed in my house and is right above my daughters room. the problem is even after i go cruisen and park it while leavn the garage door open for a while the fumes permiate the house for the next couple of days. my daughters room gets it the worst. so as of late ive been taken it easy. any advice how to solve this problem? ( i think my brest option is to get two exhaust fans (intake/exit) to solve this issue but who would i be calln for this job? much abliged
rabelson51 is offline
post #2 of 6 (permalink) Old Jun 16th, 11, 10:07 PM
69-Pace's Avatar
Re: exhaust fumes
Pull down all the sheet rock and have "wall-tight" spray foam installed then double mil vapor barrier with all seams taped, then re-sheet rock with tight seams and corners, tape and double mud and caulk all edges. This will seal the entire garage against exhaust leakage and bring it up to current code. See the Mike Holmes website for details and brands used.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 6 (permalink) Old Jun 17th, 11, 12:06 AM
Pete
Re: exhaust fumes
Funny, I just watched that same episode of holmes inspection. Good advice. Garage needs to be completely sealed from the house, vapor and fumes will go through the smallest opening.
In addition get rid of the carburetor and switch to fuel injection. More power, better mpg, more reliability, cleaner, easier to start when cold, etc.
Pete
1968 Camaro
2009 Porsche 911 Carrera S
Pete68 is offline
post #4 of 6 (permalink) Old Jun 17th, 11, 01:06 AM
darrell
Re: exhaust fumes
try venting fuel tank -or loosen cap after driving and see if it helps
97Z4C is offline
post #5 of 6 (permalink) Old Jun 17th, 11, 04:14 AM
Kevin
KevinW's Avatar
Re: exhaust fumes
Try leaving it outside after you get back, once it cools bring it in.
Kevin
KevinW is offline
post #6 of 6 (permalink) Old Jun 17th, 11, 06:38 AM Thread Starter
rara51
Re: exhaust fumes
thanx guys. how much would it run me to vapor seal the garage (aprox 20x20)?
