No compression on left bank - Team Camaro Tech
post #1 of 13 (permalink) Old Jun 20th, 11, 01:25 PM Thread Starter
ryan
ok so awhile ago i did a head gasket job on my car for both heads and when i put it all back together It would start if i gave it some throttle but it would die once i got off it. the spark plugs would get carbon and gas fouled also no compression on left bank cylinders but good compression on right. when i was putting the car back together i did the proper procedures for the valve lash and top dead center also did the rocker arm tightening procedure. Any ideas?
camaroprodigy is offline
post #2 of 13 (permalink) Old Jun 20th, 11, 03:12 PM
NHBandit's Avatar
Re: No compression on left bank
How experienced are you at doing this type of work ? The easiest thing to double check at this point is the valve adjustment. It's very possible that's the only thing wrong. If you haven't done it a bunch of times ask someone to help you who has.
NHBandit is offline
post #3 of 13 (permalink) Old Jun 20th, 11, 03:59 PM
Banned
Bethanne
Nashville Beth's Avatar
Somebody here had the same problem and it was a mis-placed intake gasket on one side.
Nashville Beth is offline
post #4 of 13 (permalink) Old Jun 20th, 11, 10:41 PM
darrell
not intake gasket--probably loosen the valves on that side a turn and chek compression--did you install head gaskets with right side facing up--if you install them wrong they can leak between cylinders-example #1 going on compression stroke and # 3 piston is going down (swaping compression)
97Z4C is offline
post #5 of 13 (permalink) Old Jun 21st, 11, 11:09 PM Thread Starter
ryan
ok found it had a bent rod from when i didnt do the valve lash and tried starting it with the rocker arms on too tight
post #6 of 13 (permalink) Old Jun 22nd, 11, 02:28 AM
darrell
that means they bent because the valves hit the piston -what about the valves-need to do leak down test or pull the head--you know you can adjust all the valves when your #1 TDC and #6 TDC right
97Z4C is offline
post #7 of 13 (permalink) Old Jun 22nd, 11, 11:45 AM Thread Starter
ryan
ya thats what i did after i realized i tightened the rocker arms to tight and didnt do the valve lash
post #8 of 13 (permalink) Old Jun 22nd, 11, 05:52 PM
Harry
dawg's Avatar
Doh!
434 stroker
US Navy retired
dawg is offline
post #9 of 13 (permalink) Old Jun 22nd, 11, 05:58 PM
You have very well bent thw valves, Pull head and check. One bent push rod does not explain No compression on a whole bank.
john68 is offline
post #10 of 13 (permalink) Old Jun 24th, 11, 01:04 AM Thread Starter
ryan
im now doing a whole engine rebuild im pulling the engine out replacing the crankshaft, camshaft, and a piston that broken and fell into the crankcase because the dude thats helpin me dropped a damn drill bit into the cylinder through the sparkplug hole...if any of you live in tx feel free to stop by and help..lol
post #11 of 13 (permalink) Old Jun 24th, 11, 03:51 AM
darrell
uhh if more than one valve hit pistons better look at replacing all pistons --may look good but piston ring gland might have closed--where you at in tx
97Z4C is offline
post #12 of 13 (permalink) Old Jun 24th, 11, 10:38 PM Thread Starter
ryan
i'm in grand prairie little south of dallas
post #13 of 13 (permalink) Old Jun 25th, 11, 03:45 AM
darrell
a little too far from me-but i am gonna be there the last weekend of july for girls softball tournament
97Z4C is offline
