90 Camaro RS 3.1 cranking issues - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 21st, 11, 10:37 AM Thread Starter
El
My 1990 Camaro RS 3.1 was starting great until I let sit without a battery for a month. Now, when I insert the key and try to turn it on, it doesn't turn all the way to the on position. My Camaro won't crank! Everything else operates as it should, but I can't get the key to start the vehicle. I haven't tried to push start the car. Any suggestions?
ekm57 is offline
post #2 of 2 (permalink) Old Jun 21st, 11, 01:08 PM
Vintage 68's Avatar
Wink Re: 90 Camaro RS 3.1 cranking issues
1st - welcome to Team CAMARO
Most likely the anti-theft system kicking in during start attemps ...
The PCM may need reprogrammed for the key VATS code, or something in the system is not working correctly.
Try reading up on VATS interlock system and testing - http://shbox.com/1/pass_key.html
Hopefully some of the true 4th gen guys will see the bump and chime-in ...
1968 Convertible
Some trucks
Vintage 68 is offline
