I can really use some help - Team Camaro Tech
post #1 of 16 (permalink) Old Jun 24th, 11, 11:55 PM Thread Starter
Cole
Angry I can really use some help
i have a 95 3.4l camaro and lately its been having trouble strating. I dont think its the fuel pump because it runs great after a while of driving. its almost like its starving for gas when its trying to start and during the 1st minute of driving until i give it a lot of gas i feel like its getting worst and i really want to fix it. i dont want to take it in some place and pay a bunch of mechanics that dont know what there talking about. Any ideas please let me know
MagnifiedEgo is offline
post #2 of 16 (permalink) Old Jun 29th, 11, 03:55 PM Thread Starter
Cole
Exclamation i can really use some help
I have a 3.4l 95 camaro but its having trouble starting. it has trouble starting when its been sitting. im pretty sure its not the fuel pump because i can hear it when i turn the key. its starts after about 10 times and i have already had to replace the starter. i really want to get this fixed so i dont have to keep replacing my starter. im thinking it could possibly be bad ignitors or spark plugs but after i replace those im thinking about replacing the ignition module but its like $90 bucks and i rather not buy it if thats not the problem. but if anyone could help me i would really appretiate it.
post #3 of 16 (permalink) Old Jun 29th, 11, 04:10 PM
Re: i can really use some help
Can you tell us more? The starter turns over, you can hear the fuel pump, does it sputter at all? What does it do when it does start? Usually if it is timing the computer figures things out after 3 or 4 turns. Is it actually 10 times?
Ishmael is offline
post #4 of 16 (permalink) Old Jun 29th, 11, 04:20 PM
Vintage 68's Avatar
Thumbs down Re: 95 Camaro
Please follow the site rules you agreed to when signing up - and Do Not Double Post
Sere - https://www.camaros.net/forums/showthread.php?t=197167
1968 Convertible
Some trucks
Vintage 68 is offline
post #5 of 16 (permalink) Old Jun 29th, 11, 04:24 PM Thread Starter
Cole
Exclamation 95 Camaro
i have a 3.4 95 camaro and im having trouble getting it to start everytime it sits for an hour. i dont think its the fuel pump because i hear it everytime i turn the key. It starts after about 10 cranks but its wearing out my starter. im thinking about buying a ignition module but its like 90 bucks and i dont want to waste money if thats not the case i would appreciate it if anyone could give me some advice
post #6 of 16 (permalink) Old Jun 29th, 11, 04:31 PM
Vintage 68's Avatar
Angry Re: 95 Camaro
QUIT MULTIPLE POSTING THE SAME QUESTION
Read the site rules
1968 Convertible
Some trucks
post #7 of 16 (permalink) Old Jun 29th, 11, 04:32 PM Thread Starter
Cole
well it cranks over but theres not enough fuel going to the motor because after it finally starts it shakes right at first while im driving and then i give it a lot of gas and then its fine. and after i get it running it runs fine
post #8 of 16 (permalink) Old Jun 29th, 11, 04:34 PM
Vintage 68's Avatar
Thumbs down Re: i can really use some help
If you'd quit multiple posting (against site rules you "agreed" to ) you just might get more responses from folks who have fixed this before and could help you - like me ...
1968 Convertible
Some trucks
post #9 of 16 (permalink) Old Jun 29th, 11, 04:36 PM Thread Starter
Cole
ya i know thats my bad but i just figured out how to post things on this website i dont know why it was so hard for me to figure out and then i finally saw this spot which is where everyone was posting there problems but it just took me the third time so im sorry
post #10 of 16 (permalink) Old Jun 29th, 11, 04:39 PM
69-Pace's Avatar
Re: 95 Camaro
LOL Triple posted - https://www.camaros.net/forums/showthread.php?t=197169
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #11 of 16 (permalink) Old Jun 29th, 11, 04:55 PM Thread Starter
Cole
Re: 95 Camaro
sorry i didnt know where to post
post #12 of 16 (permalink) Old Jun 29th, 11, 05:14 PM
Vintage 68's Avatar
Thumbs up Re: i can really use some help
This isn't 'wiki-camaro' ... answers can take time.
All car-folks here trying to help each other out - no paid staff or 'answer men' working on it.
Junks up the site to have bunches of post (from the same guy) not following site guidelines and makes answers take even longer and you will most likely get conflicting/bad info.
Now - back to your problem ...
Most likely is not anything to do with the ignition system - can happen, but usually does not effect start/idle ...
Most likely is the fuel pressure (or lack of it) at start/crank and initial idle ...
Have you checked the resting (engine off sitting in drive), 'key on' (but not started) and starting (cranking) fuel pressure readings?
If you don't have a fuel pressure guage set-up, most of the chain auto parts stores will "loan" you one.
Just because a pump makes noise, doesn't mean it's providing the proper amount of fuel ...
There should be @40PSI as soon as you turn the key on the first time - when you're hearing the "pump run" after just turning on the key.
It then should stay at @40PSI during cranking.
Once a fuel system is pressurized it should hold that pressure for a long time - days, not hours ...
Failure of the system to hold pressure points to a leak, which you would most likely have seen or smelled by now, or a bad check ball (valve) in the pump allowing pressure to bleed off.
The two (2) things that effect it are:
Fuel Pressure Regulator;
* should limit pressure to @40PSi after start
* check the internal diaphram to make sure it is good and doesn't leak - pull vacuum line off and check with vacuum source or smell for fumes in line at least.
* check to be sure it controls pressure when throttle is opened - it if doesn't then the internal valve may be bad and is not returning excess fuel to tank and can overpressure the injectors.
* they are cheap (<$60) and easy to change
Fuel Pump;
* should provide @40PSi of pressure when key is turned to 'on' for a few seconds
* should 'hold' that pressure during cranking
* should provide @40PSI of pressure once engine fires and idle is stable.
* should hold that pressure well past an 'overnight' set - or as stated above the internal check is failing.
* they are expensive (>$150) and can be hard to change for some.
Not that it will normally cause this type of problem - but, have you checked the fuel filter?
Be sure to buy one and change it if you install a new pump or regulator.
1968 Convertible
Some trucks
post #13 of 16 (permalink) Old Jun 29th, 11, 05:53 PM
george
Sounds like a fueling issue.Right now, i would install a pressure gage on the fuel rail to aid in diagnosing.Your symptoms are indicative of a fuel pump foot valve fail.The rail does not hold pressure and the extended crank/starts but runs rough/cleans up.. is air being purged from the rail.Tap into the shrader/service valve and confirm that the pump will build and hold 42 psi after the 2 second key up prime.
George
68 Camaro
8-71 blown 461 Rat on E-85
fatblock is offline
post #14 of 16 (permalink) Old Jun 29th, 11, 09:37 PM
Could be the ect (engine coolant temperature sensor) if the computer sees the engine as warmer or colder than it is, the fuel ratio on start up will be far enough off that it will run like a turd.
Get the manual, look up the specified resistance and where the sensor is...
400bird is offline
post #15 of 16 (permalink) Old Jul 1st, 11, 12:15 AM
darrell
Re: I can really use some help
agree on fuel-chek and replace filter first then furl pressure and regulator-chek if any fuel is getting on vacuam port to regulator, it shouldnt-and 1st of all do you have a hard code- engine light staying on---chek code and go from there
97Z4C is offline
