Camaro Wiring - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 27th, 00, 04:07 PM Thread Starter
Can anyone tell me where the smaller wire goes on a solenoid on a 83 Camaro ? This car had a 350 engine put in it and someone messed with the wiring before I got it. They were running a wire from the battery to the distributor. Without this wire the car does nothing! It has no headlights, dashlights or will even crank without this wire.
I checked the wire that is on the "S" on the solenoid and discovered that, not only will it not take current, it's also not connected to anything. Could anyone tell me where this wire goes ?
[This message has been edited by LDRyan31 (edited 02-27-2000).]
LDRyan31 is offline
post #2 of 7 (permalink) Old Feb 27th, 00, 07:48 PM
there should be a smaller bolt coming out of the solinoid that the wire attaches to
Athorn4941 is offline
post #3 of 7 (permalink) Old Feb 28th, 00, 06:49 AM
Hey, LD. I sent you a long email on this stuff, but for your question here, there are 3 terminals on the solenoid. The big one gets the battery pos cable, and up to 3 secondary wires, one to the alternator and the others to the fuse block. These are the wires that actually supply power to the car. There are 2 smaller studs on the solenoid, the one labelled "S" goes to the ignition switch, this is the wire that cranks the starter when you turn the key. The third one is left over from point ignitions and is not connected on a modern car.
Check the fusible links in the wires coming off the starter BAT terminal.
post #4 of 7 (permalink) Old Mar 3rd, 00, 03:35 AM
Another thing to check , some of the wires coming from the BAT terminal from the starter have Fusable links installed in them, if all is hooked up correctly and still no power then this also might be a issue
Chris Edwards is offline
post #5 of 7 (permalink) Old Mar 5th, 00, 03:37 PM
Red face
Jim cheated and edited his message to include mine.. his fusable links part was honstly not there when I posted it...
post #6 of 7 (permalink) Old Mar 6th, 00, 06:09 AM
Hey Chris, not my message above does not indicate it has been edited... Ha Ha
post #7 of 7 (permalink) Old Mar 6th, 00, 07:11 AM
heheh guess that falls under my DA/SS post about the RS/SS issue.
heheheh
