Speedometer calibration - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 30th, 01, 06:38 PM Thread Starter
I would like to know if anyone here has any information as to what drive and driven gears I need to make my speedometer accurate. In order for me to order them from General motors I need the oem part number. I have a 68 Camaro with a 3:73 diff, turbo 350 trans and 255/60R 15 tires. Your help will be appreciated thanks Garry.
Garry Gagnier is offline
post #2 of 4 (permalink) Old May 1st, 01, 08:57 AM
Take it to a shop that can put it on a chassis dyno. they can figure out the % it is off and chose the correct gear. and it is not very expensive.
Matty 93 TA is offline
post #3 of 4 (permalink) Old May 1st, 01, 05:33 PM
Thumbs up
Garry
At the bottom of THIS! page are two links that should tell you everything you need to know. They are the Speedo Calibration and [Speedo Gear Selection[/b] links. They worked for me. Good Luck
Rick Schaefer
68 Camaro
72 El Camino
TPI350/700r4
rick is offline
post #4 of 4 (permalink) Old May 1st, 01, 06:20 PM Thread Starter
Thanks Rick I put this site on my favorites and I will look into it soon. I hope I can find a dealer who can give me the part numbers from the tooth count combinations. Garry
