Noise when shifting gears? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 9th, 02, 02:46 AM Thread Starter
Hi everyone, this is my first post here!
I have a 93 V6 with +163K that still runs good except for a rattling noise around the gearbox when shifting gears. This only happens when its cold and only for the first few miles. After that, its fine! Keep in mind, it happens ONLY when moving the shifter, and is not related to engaging the clutch.
Thanks up front!
ITSPRPL is offline
post #2 of 4 (permalink) Old Aug 9th, 02, 03:35 AM
Is it the stock tranny? What kind of trans?
Baby68RS is offline
post #3 of 4 (permalink) Old Aug 9th, 02, 06:28 AM Thread Starter
Sorry, factory 5-speed manual transmission
kind of sounds like something's loose... and by the way... I can usually keep it from rattling by pulling out, engaging the clutch and very slowly shifting gears after the rpm's have returned to idle. but obviously, this results in VERY slow acceleration.
( not something you want if a semi is bearing down on your backside )
ITSPRPL is offline
post #4 of 4 (permalink) Old Aug 9th, 02, 06:33 AM
Probably an input shaft bearing loose(worn) until it heats up to remove the clearance.
I'd try some synthetic lube in the gear box.
Can't hurt
