my 97 dies when it gets warm - Team Camaro Tech
post #1 of 12 (permalink) Old Jul 11th, 11, 10:35 PM Thread Starter
darrell
my 97 lt1 runs great but recently it dies after running for awhile and its becoming sooner and sooner--the dist , coil, wires, plugs, and perty much everything was replaced 6 months ago--i have had the fuel gauge on it when it starts to act up--it holding fuel pressure , so i dont think its that-havent thrown a code until this last time--i am planning on throwing a icm at it -what yall think
97Z4C is offline
post #2 of 12 (permalink) Old Jul 11th, 11, 10:45 PM Thread Starter
darrell
Re: my 97 dies when it gets warm
when it starts acying up--starts missings on all cyj. at 4 grand within 1min its at 1000rpm and dies--let set for an hour and fine again for awhile
97Z4C is offline
post #3 of 12 (permalink) Old Jul 12th, 11, 04:16 AM
Optispark.
post #4 of 12 (permalink) Old Jul 12th, 11, 01:09 PM Thread Starter
darrell
think the optispark is going bad again
97Z4C is offline
post #5 of 12 (permalink) Old Jul 12th, 11, 07:53 PM
Send a message via AIM to Satatic
Unplug both the front 02 sensors. If the problem doesnt happen again then there you go.
Satatic is offline
post #6 of 12 (permalink) Old Jul 12th, 11, 08:10 PM
Steiner
I think if the Opti signal drops out it turns off the injectors. Might be able to free-rent a good scanner from the parts store and watch the RPM signal at the ECU. Unfortunately the test procedure for an Opti is pretty much "replace with a known good one". I think when it dies you should be able to turn the engine over and listen for the injectors or watch the RPM signal.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 12 (permalink) Old Jul 12th, 11, 09:13 PM Thread Starter
darrell
thanks i will let yall know
97Z4C is offline
post #8 of 12 (permalink) Old Jul 14th, 11, 05:23 AM Thread Starter
darrell
well i got hard headed and replaced the ICM since this this is the only thing that hasnt been replaced on car and wanted peace of mind--seemed like it ran better but with a/c on- it started reaching 200 driving in neighborhood -so i made it home and found that the fans was not running constant with a/c on, the fan would cycle with temp like i had a/c off-i cooled the car after it shut down again -restarted and inspected fans-i ran the engine with a/c off and the fan cycled once it got to 180 on gauge-it climbed to 215 and the engine started cutting out at this time-so i think the problem is a fan issue that the opti spark or coolant sensor gets too hot it cuts out firing( if i have the a/c on and turn the ignition to run position, the fans should have power or does the motor have to be running)
97Z4C is offline
post #9 of 12 (permalink) Old Jul 14th, 11, 05:27 AM Thread Starter
darrell
the fan was not cycled on when it shut down at 215
97Z4C is offline
post #10 of 12 (permalink) Old Jul 14th, 11, 12:02 PM
Steiner
Here's a site that should have everything you need. Remember it from back when I had an LS1 car.
http://shbox.com/1/4th_gen_tech1.html
Here's the direct link to the cooling stuff:
http://shbox.com/1/4th_gen_tech2.html#cooling
'69 Camaro
500hp/538lbft
Steiner is offline
post #11 of 12 (permalink) Old Jul 15th, 11, 08:01 AM Thread Starter
darrell
thanks steiner--this is a great lead to solving my problem and i think i know whats happening now
97Z4C is offline
post #12 of 12 (permalink) Old Jul 16th, 11, 04:36 PM Thread Starter
darrell
well -i worked on it today and its not running as hot--havent stalled on me yet-it always has shutterd at wide open throttle when its about to shift gears and not even doing that anymore-so what was the problem--bad connection at plug to opti spark--thanks again all for putting me on the right track-now i am off to car show with it about time to enjoy it
97Z4C is offline
