Check Engine Light Is Moody!! - Team Camaro Tech
post #1 of 3 (permalink) Old May 6th, 01, 03:33 PM Thread Starter
I have a problem with my check engine light. I have a stock 1985 Camaro with 4-speed auto. The problem is when the car is driven over 65 MPH the check engine light will come on and off periodically (every few minutes). If I slow down under 50 MPH the light goes off. Also, if I never go over 60 MPH the light will never come on. I've check vaccuum hoses, oil, water, etc...all good. Any ideas?
FlyinCamaro is offline
post #2 of 3 (permalink) Old May 6th, 01, 04:13 PM
David Pozzi
davidpozzi's Avatar
Get it checked for trouble codes, maybe a bad 02 sensor?
You may not get a lot of help on it here as this is mostly a first gen forum.
Take a look here: http://www.f-body.org/ http://www.nastyz28.com/
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
davidpozzi is offline
post #3 of 3 (permalink) Old May 6th, 01, 05:48 PM
Dale
Sounds like the classic symptoms of a code 32.This code says the EGR valve is not functioning properly.Jump the ALDL, pin A to B (usually the 2 top terminals on passenger side of connector)turn the key on,engine off.The service engine light will flash a code 12, 3 times(1 long flash,2 short flashes.The trouble codes will follow.count the flashes,code 32 will be 3 long flashes,and 2 short flashes.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
