Noisey Roller Rockers?? - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 15th, 02, 12:08 PM Thread Starter
I recently just completed a head change..Trick flow heads, TF roller rockers and TF Hardened pushrods..Problem or should I say question is..
I have adjusted the drivers side rockers 3 times already (Zero+ 1/4 turn Hydraulic cam Lunati [email protected] and 515 lift)...And even though I can't here anything while standing next to the engine while running..I do here a very faint click coming from the drivers side valve cover using my stesescope(SP????)..Could it have something to do with the headers being cut down and rewelded with a close bend(Clearance issues) on the driverside..There are NO header leaks on the drivers side....(I do have a collector leak on the passenger side)).....Thanks again
Restored 68 Camaro R/S 327 4 speed
Restored 55 chevy Belair
Blown, Fuel Injected
http://community.webshots.com/user/badcaiman
76 Limited edition T/A # matching
26 Ford Roadster..Pro street
79 Corvette..Frame off restoration..(Don't ask WHY )
Badcaiman is offline
post #2 of 10 (permalink) Old Jul 15th, 02, 01:23 PM
Eric
Zero lash + 1/4 turn is on the loose side IMO especially if it is a new cam and you have new rocker arms. The rocker bearings will loosen a little with breakin and so will the cam and lifters. I always set them to zero lash plus 1/2 turn. Maybe you have one that is a touch on the loose side.
Keep in mind that roller rockers are a little noisey when working properly - I'm assuming that since you only hear it on one side that you MIGHT have one that a little loose. Probably nothing to worry about at all.
Eric68 is offline
post #3 of 10 (permalink) Old Jul 15th, 02, 06:32 PM
xodus921
Guest
Posts: n/a
RELAX!!!!
You know your never going to enjoy your car....
Just kidding with you man...
Tony
<UL TYPE=SQUARE>
<LI>1979 Z-28, 350, Th350- Edelbrock Performer RPM cam and intake, Holley 650, Trick flow twisted wedge heads, dynomax headers,flowmaster american thunder exhuast[/list]http://hobbystage.net/camaro/xodus921/
post #4 of 10 (permalink) Old Jul 16th, 02, 03:22 AM
I have trick flow heads with roller rockers, every time I get on it hard, the valve train is a little noisy. I have adjusted the valves 3 times, and i still here the ticking noise sometimes. I think that it is just normal.
1968 Camaro Rally Sport Convertible
bigal698177 is offline
post #5 of 10 (permalink) Old Jul 16th, 02, 11:17 AM
I went through this with my 57b a while back. What I finally figured out the valve covers were just barely touching the lifters. Look inside the covers and see if you have any marks.
korvettekarl is offline
post #6 of 10 (permalink) Old Jul 16th, 02, 11:19 AM
Bob
I'd keep them right at zero plus a quarter turn through the breakin period. Get some miles on the motor and then play with them. My hydraulic rollers are a little noisy also.it isn't worth worrying about.
phel69 is offline
post #7 of 10 (permalink) Old Jul 17th, 02, 03:14 AM
Cameron
I too have Trick Flow heads and roller rockers. From what everyone says, they are just noisy. It took me a while to accept that, but I finally did. If you are sure that the valves are adjusted right, then I would leave it alone and not worry about it.
Cameron is offline
post #8 of 10 (permalink) Old Jul 17th, 02, 04:48 AM
It just stands to reason that they will be noisy. Being aluminum and the thermal expansion that comes with the material If the rocker expand even slighty It would change the lash significantly.not to mention the areas that the rollers occupy they expand as well the steel does not expand as much and voila. Increased clearance=some noise.
67 prostreet BB Camaro
71 BB SS Chevelle (clone)
2002 35th anniv SS Z28 conv.
Milan is offline
post #9 of 10 (permalink) Old Jul 17th, 02, 05:11 AM
Rick
If you need a stethoscope to hear them, I think you're fine. When I do that, I hear all kinds of interesting sounds.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
post #10 of 10 (permalink) Old Jul 17th, 02, 01:02 PM
Ray
I had this problem when I installed aluminum roller rockers on my Trick Flows years ago. The problem was like korvettekarl said, the rockers were just barely tapping the inside of the valve cover. I took them off and used a bench grinder on to remove a little material and the noise stopped.
Ray
68SSConvt is offline
