91 RS Wont Start - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 9th, 02, 07:28 AM Thread Starter
My 91 Rs started I backed it up 5 feet
it died and will not start it turns over
has fire pressure to the manifold
fuel i read the last years posts
i have good compression checked all grounds even banged on the tank with rubber mallet
my question is were is the ecu fuse my camaro is metric there is no fuse by the battery also how do i check the error codes without the 12 pin plug any 1991 rs metric owners out there help please
hometownelec is offline
post #2 of 7 (permalink) Old Jan 9th, 02, 07:18 PM
You didn't say if you checked spark.There is a aldl connector under your dash somewhere for checking codes.You'll just have to look around for it.Don't worry about that for now.Check basics.As long as the check engine light is on with key on engine off then ecm fuses are fine.Why are you calling this car metric?? Check for spark before you reply.
sschevyfan is offline
post #3 of 7 (permalink) Old Jan 10th, 02, 04:42 AM
Got your e-mail.How are you checking fuel pressure? Spray some starting fluid into throttle body just to be sure it's not fuel related.
post #4 of 7 (permalink) Old Jan 10th, 02, 11:37 PM Thread Starter
Talking
I tried the starting fluid still nothing
im going to pull the plugs saturday
do you know what the coil and plug wire
voltage should be i,ve ordered a manual
couldnt find one here in truck country
Thanks again
post #5 of 7 (permalink) Old Jan 10th, 02, 11:41 PM Thread Starter
Cool
P.s checked the pressure with a thumb nail
it rebuilds each time i turn the key on
strong enough to hit the hood around 12 to 16 pds i would guess
post #6 of 7 (permalink) Old Jan 11th, 02, 05:20 AM
This is port fuel injection right? you said you used your thumb nail so I assume your pushing the schrader valve??The pressure should be up in the 40 psi range with the key on engine off.Running it's a little lower maybe 36 psi. Go buy a gauge.You can get one from auto parts stores for around 40.00.If it would not start on the starting fluid you probably have a ignition problem.pull a wire off and hold it from ground about 1/4-1/2 inch.actually stick a screwdriver in the plug wire so it touches metal terminal and put the screwdriver near ground.look for a nice blue spark.Check that then get back to us.
post #7 of 7 (permalink) Old Jan 11th, 02, 01:16 PM Thread Starter
Talking
yeah its alive
turned out to be my over priced delco 1
sparkplugs fouled black carbon every where
im assuming due to cold and ice
it dosnt go any where i start it to keep
its battery up tommorow will take it out
on hwy 40 thanks chevy fan for all youre help
i really appreciate it kent
[email protected]
