Service Engine Soon light ON!!! - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 3rd, 01, 07:11 AM Thread Starter
I have a 1996 V6 Chevy Camaro (manual) with about 64,000 miles on it. I have kept up on all its maintenance and have had no problems really until today.
About 2 minutes my "Service Engine Soon" light started blinking and then just stayed on. Drives fine, not overheating, oil pressure okay...
I'm going to take my car in after work, but does anyone have any ideas as to what the problem could be? I need to figure out how much money this could take.
Thanks.
-Sarah
buckwi1d is offline
post #2 of 6 (permalink) Old Apr 3rd, 01, 09:25 AM
Rick
It's usually a sensor or a misfire. After 3-5 start cycles, the light goes off when the problem goes away. I would suggest a tuneup if it hasn't been done recently, O2 sensor. I had a loose vacuum hose trigger that as well as sparkplug wire crossfire.
RickD is offline
post #3 of 6 (permalink) Old Apr 3rd, 01, 11:29 AM
pull the codes and repost
search this section for "codes"
68ragtop is offline
post #4 of 6 (permalink) Old Apr 5th, 01, 07:08 AM
or if you dont feel like doing jack crap, just unplug the lightbulb, it wont bother you anymore.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #5 of 6 (permalink) Old Apr 5th, 01, 04:41 PM
Den
DenRS's Avatar
This may sound stupid, but did you just fill up the tank or switch brands of gas? A tank of bad gas will set off the light, but your car will run fine. Also, if you don't click the gas cap at least three clicks, the light can come on. The OBD II computer is very sensitive. I added some stp gas treatment when I got a bad tank of gas, and my light when off. If that doesn't work, probably a bad O2 sensor. Good Luck
DenRS is offline
post #6 of 6 (permalink) Old Apr 5th, 01, 05:50 PM
it can also mean you need to service the car. the puter's do this cause there are part's in the emision system that need to ba changed at various milage mark's. normaly this happen's at around 50,000 mile's. i do not know if G.M is still programing this into the ECU. i know the jap's are still doing it. and ford too.
also if the mechanic that serviced it did not clear certain code's you get the light, even if you have done the srvice on the car.
[This message has been edited by ilbl8 (edited 04-05-2001).]
ilbl8 is offline
