68 Camaro...Bad fuel gauge or sending unit???? - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 13th, 01, 03:30 PM Thread Starter
Spent the entire day trying to track down the problem with my fuel gauge...The needle is pined at approx 3 on the clock(past full)..dropped a full tank(yeah I know why full...Didn't know it was full)..Well noticed That the ground wire was loose and that the sending unit wire was missing...I wired a temporary wire to the sending unit and wired everything according to the wiring diagram on the book(middle terminal on the sending unit to the tan wire in the trunk and the black wire on the sending unit to a ground) and the needle still sits pined...If I reverse the wiring the needle goes all the way to E...If I wire it the way the book says It goes way past F.....Do you guys think I need another sending unit...Also anyone know or have the correct terminal for the sending unit(the terminals that connect to the gas tank and enter the trunk and connects in the trunk...Thanks in advance
Badcaiman is offline
post #2 of 4 (permalink) Old Jun 13th, 01, 04:08 PM
This page by The Chevelle Engineer has a real good troubleshooting procedure for the gas gauge.
rick
rick is offline
post #3 of 4 (permalink) Old Jun 16th, 01, 02:36 AM
Try grounding the sender wire to the gauge. If the gauge reads empty, chances are the sender is defective. This system has a rising fuel level w/ resistance. That menas that the gauge should read past full when disconnected, empty when grounded. Ray
RABarrett is offline
post #4 of 4 (permalink) Old Jun 16th, 01, 01:59 PM Thread Starter
Thanks for the replies...I traced it to a bad sending unit...Replaced sending unit gauge works...Longest part was removing the fuel...After that it took a solid 20 minutes on jack stands..Again thanks for all the help
