Late model block with early mechanical fuel pump. - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 8th, 01, 01:57 PM Thread Starter
I'm doing a 67 Camaro for a guy that is using a 89 T/A block with a mechanical fuel pump. It didn't look like it was going to line up right, although the pushrod did go into the block. The pattern just doesn't look correct, and it originally had a block off plate. Can this be done? do i ned an adapter?
Tyler
<A HREF="http://www.pro-touring.com/featured_cars/Camaro/Tyler_Beauregard/tyler_beauregard.htm" TARGET=_blank>
68-LT1-T56
</A>
<A HREF="http://www.pro-touring.com/featured_cars/Camaro/Tyler_Beauregard/tyler_beauregards_project_5050.htm" TARGET=_blank>
50-50
</A>
Teetoe_Jones is offline
post #2 of 6 (permalink) Old Oct 8th, 01, 02:31 PM
ZZ_430's Avatar
Tyler, I've done a few conversions similar to what you're doing and never had a problem.
The old style rod, plate, and pump bolted right up.
The newer replacement motors just have that area of the casting blank/unmachined and must use an electric pump.
I'd say try mounting it and turn the engine over by hand to check for any problems.
Don~ ZZ430DropTop
~~~~and~~~~
Pro-Touring.com DropTop
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #3 of 6 (permalink) Old Oct 8th, 01, 04:21 PM
David Pozzi
davidpozzi's Avatar
How about the cam? Is there a fuel pump eccentric on it?
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #4 of 6 (permalink) Old Oct 8th, 01, 04:26 PM Thread Starter
So i have the pump, and pushrod, and it appears that there is an escentric on the cam, but do i need a plate? When i put the pump to the block, the bottom is exposed. Am i missing something?
Tyler
68-LT1-T56
</A>
50-50
</A>
post #5 of 6 (permalink) Old Oct 8th, 01, 04:31 PM
ZZ_430's Avatar
Tyler, the plates are available at any GM dealer, or even aftermarket. If you use a chrome one, be sure to scuff the chrome or it will leak.
Don~ ZZ430DropTop
~~~~and~~~~
ZZ_430 is offline
post #6 of 6 (permalink) Old Oct 9th, 01, 06:26 PM
You need a mounting plate that bolts to the block. The fuel pump then bolts to that.
-Joe
79' Z28 4-spd- built 355, TRW flattops, WP SportsmanII heads, Crane Energizer 284/284 duration .480"/.480" lift, Edelbrock Victor Jr., Holley 750cfm, Dynomax headers, dual 3" flowmasters
joesmith69 is offline
