Highbeams kill my fuel gauge - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 1st, 11, 11:11 AM Thread Starter
Randal
Every time I turn on the on the headlights or parking lights in my 68 convert I get them but I also loose my fuel gauge. If im at a full tank it will drop to around half and anything below that will drop the needle to past empty. Its a standard dash with no other gauges but the speedo. thanks
68 CoNvErTiBle is offline
post #2 of 7 (permalink) Old Aug 1st, 11, 05:13 PM
69-Pace's Avatar
Re: Highbeams kill my fuel gauge
sounds like a ground gone bad or a bad printed circuit.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 7 (permalink) Old Aug 1st, 11, 07:58 PM
Jeremy
Is the center screw at the top of the gauge housing that mounts it to the dash? Check and see if it's missing and/or loose or the ground that goes there may not be connected?
67 Camaro
makoshark is offline
post #4 of 7 (permalink) Old Aug 2nd, 11, 05:46 AM
While your at it, you could pull the dimmer switch and see if dirt and moisture is causing some voltage to go to ground.
Ron
The
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #5 of 7 (permalink) Old Aug 3rd, 11, 11:32 AM Thread Starter
Randal
Thanks guys I'll try the center screw first and the printed circuit last.
post #6 of 7 (permalink) Old Aug 3rd, 11, 01:44 PM Thread Starter
Randal
BINGO bad ground. The tab that dose the grounding was not doing its job but all seems well now. Thanks.
post #7 of 7 (permalink) Old Aug 3rd, 11, 03:56 PM
69-Pace's Avatar
69-Pace is offline
Tags
fuel gauge
