NO Crank! PLS help - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 9th, 01, 02:19 AM
rogleete
Guest
Posts: n/a
My car won't crank. one sec i pull it out of the garage then when I go to turn it back on...nothing, it turns over but won't fire. Checked power at the coil and got nothing. checked the wires and therer all hooked up fine. has msd6a box. could the box be bad? please help, daily driver
post #2 of 8 (permalink) Old Mar 9th, 01, 02:55 AM
Assuming your battery has a good charge on it, you could have a bad battery cable, corroded or loose cable connections at the starter or the ground (block), or even a bad ignition switch. Make sure your cable connections are clean and tight. Is the starter even clicking when the key is turned?
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #3 of 8 (permalink) Old Mar 9th, 01, 04:13 AM
rogleete
Guest
Posts: n/a
Yes the starting is turning over...the car makes the general noise it does when you try to crank it..it just won't start. I haven't checked to see if the plugs are getting any spark...will do that today after classes. But the plugs are all new, so its not the actual plugs. i think it has to do with the msd6a box. but i dont' know what, the box is getting power when the key is turned on. but no power to the coil. i tried a dif. coil so its not the coil itself
post #4 of 8 (permalink) Old Mar 9th, 01, 01:24 PM
Bruno
Check your MSD's ground cable.
ORENCH is offline
post #5 of 8 (permalink) Old Mar 9th, 01, 03:31 PM
David Pozzi
davidpozzi's Avatar
If you have an msd box with the point type distributor, check the points. The box reduces voltage through the points, and the rubbing block can wear down and screw up the dwell.
Also any little foreign objects can interupt the flow of juice between the contacts. Dust or oil can prevent power from getting to the msd box.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #6 of 8 (permalink) Old Mar 10th, 01, 05:59 AM
Learn how to jump around the box (msd website) I had a 69 camaro with a 6A and it crapped out on me, it just shut off while I was driving down the road. after trying to start her for a while, pumping cursing, the whole trip I jumped around the MSD, then i tried to start it again ....
BANG!!! what a backfire!!! the intake was loaded with fuel from trying to start, it ran after that, and i rebuilt the carb, changed the MSD ans away I went...
ps ypou southern guys are funny, when you say crank, you mean run, when us yankees say crank we mean turn over.
"it wont crank"... try the battery and starter... but it turns over fine... huh??"
[This message has been edited by 68ragtop (edited 03-10-2001).]
68ragtop is offline
post #7 of 8 (permalink) Old Mar 13th, 01, 03:48 AM
hillbilly University
Chris Edwards is offline
post #8 of 8 (permalink) Old Mar 15th, 01, 04:03 AM
Check the main hot wire comming off the box mine broke 1 time and would not start get a voltege meter it helps with theas cars
melrod is offline
