Wheel knocking - HELP - Team Camaro Tech
post #1 of 8 (permalink) Old May 23rd, 02, 01:41 PM Thread Starter
Any help in diagnosing this would be greatly appreciated. I am not a mechanic. But I like to do the easy things myself.
Ok, hereís my problem.
When driving down the road I get a knocking noise coming from I think the front wheels. This noise stops when I depress the brake pedal. I also think that it goes away when going around a turn, but not sure on that one yet.
I've taken all the wheels off and spun them as fast as I could by hand and could not recreate the noise. I did that same with the rear wheels, put in neutral, jacked the rear end up and spun wheels and yet no noise.
But I'll be damned, as soon as I go back out on the road, there it is. Its driving me crazy.
Iím ok with taking it to a garage, but if its an easy fix Iíd rather do it myself
pony is offline
post #2 of 8 (permalink) Old May 23rd, 02, 03:20 PM
ZZ_430's Avatar
Could be the pads are loose in the caliper.
Have someone press pedal, and clinch the tabs over with big channel locks.
Also check the caliper mounting bolts for proper torque.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
[This message has been edited by ZZ430DropTop67RS (edited 05-23-2002).]
ZZ_430 is offline
post #3 of 8 (permalink) Old May 23rd, 02, 04:04 PM
Have you checked your ball joints? With the brakes applied it could be loading them in such a way that they don't knock.
travis is offline
post #4 of 8 (permalink) Old May 23rd, 02, 04:40 PM Thread Starter
I've taken the wheels off and the pads are a little loose, is this normal? or should they be tight?
thanks
pony is offline
post #5 of 8 (permalink) Old May 24th, 02, 05:01 AM
If front drums, then the self adjusting spreader is too far open. If front disc, then possible warped rotor making the pad flop back and forth.
On either setup, if someone tightened the spindle/hub nut too tight, then with car weigh the small outer bearing is locking up. When the small bearing locks up, then the bearing race will start to turn instead. If that is the case then you can take the outer bearing out and the race will move back and forth proving the slop.
bonecrusher67conv is offline
post #6 of 8 (permalink) Old May 24th, 02, 07:00 AM
also check the tie rods. They will make noise when "unloaded" and go away when under brakeing or cornering.
67 prostreet BB Camaro
71 BB SS Chevelle (clone)
2002 35th anniv SS Z28 conv.
Milan is offline
post #7 of 8 (permalink) Old May 24th, 02, 05:33 PM
David Pozzi
davidpozzi's Avatar
what year?
four piston or single piston brakes?
David's Motorsports page
First Gen Suspension Page
davidpozzi is offline
post #8 of 8 (permalink) Old May 31st, 02, 06:34 AM
wheel bearing?
70rsCamaro is offline
