'82 Camaro - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 27th, 99, 01:45 PM Thread Starter
This Camaro has a V6 that blew, I tried to replace it with a used engine, now it rattles
as if it would fall apart. Some mechanics I've taken it to say it's probably a bent flywheel (aka. flexplate) Any ideas?
Deidre is offline
post #2 of 2 (permalink) Old Sep 27th, 99, 03:36 PM
Quite a few of the later engines require a weighted flywheel to balance the engine. Called external balance flywheel. Check with local parts place to determine if the engine year and model you installed requires this. tom
tom3 is offline
