white smoke - Team Camaro Tech
post #1 of 6 (permalink) Old May 23rd, 01, 07:53 AM Thread Starter
everytime i start my car white smoke comes out of the tail pipe. i have an '89 rs camaro, what is the deal? and it sounds like my valves are rattling, what causes that?
My1stCamaro is offline
post #2 of 6 (permalink) Old May 23rd, 01, 09:28 AM
white usually means antifreeze leak,light blue is oil burning,which in your case could be worn valveguides/seals.
sldhd is offline
post #3 of 6 (permalink) Old May 23rd, 01, 05:10 PM
Gary
It's antifreeze. It looks like your head gasket is ready to fail.
Gary Dorion is offline
post #4 of 6 (permalink) Old May 24th, 01, 03:03 AM Thread Starter
Is it expensive to get those parts replaced?
post #5 of 6 (permalink) Old May 24th, 01, 06:47 AM
Not if you do them early...I would replace them now.If it goes on, you could run into alot more expense.
383 Speed-O-Motive stroker kit with Holley 750DP, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and Hughes 3000 stall.Powertrax NoSlip Locker
Tracy Focht is offline
post #6 of 6 (permalink) Old May 24th, 01, 02:50 PM
Gary
The cost will be alot less to replace parts now, than when the car is dead on the road.
