67 RS/SS headlight wiring - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 19th, 11, 08:59 PM Thread Starter
Phil McCullough
My 67 RS/SS headlight system has been rebuilt, new motors, new relays, bulbs, replaced one limit switch, the others check OK, new 10 amp breaker. It has the original wiring harness (s) that was taken apart, cleaned, re-taped, contact connections cleaned re assembled. The headlight doors open, lights come on when headlight switch is pulled and go off when the switch is turned off. The headlight doors close when the Ignition switch is in the on or accessory position all as it should be HOWEVER the headlight motors keep on running after the doors close.
As stated the limit switches are working and the system shows ground on the bottom side of the switches (all of them). Pulling the wire off the top side of the offending limit switches will stop the motors turning, in fact just pulling the passenger side top wire (on close side) will stop the motors. My system is wired per the very good instructions provided in the archives and the tests suggested followed as best I can understand them (David Pozzi's postings). Most of the rest of the wiring in the car is now working though it has been out of the car for 30 years. There are no un-accounted for wires in or around the front wiring of the car?
I am at my wits end and don't know where to turn for assistance. Previous posts have had little response, I know it's a 67 original and probably not many are being worked on but I remain hopeful for some suggestions. hipirn
hipirn is offline
post #2 of 7 (permalink) Old Aug 20th, 11, 10:42 AM
Re: 67 RS/SS headlight wiring
I have a trouble shooting guide on my web page but for some reason it's down. PM me with your email and I'll send it to you in a zip file.
Ron
The “
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Geezer is offline
post #3 of 7 (permalink) Old Aug 20th, 11, 11:18 AM Thread Starter
Phil McCullough
Thank you kindly JYD/Ron: My e mail address is [email protected]
hipirn/Phil Mc
hipirn is offline
post #4 of 7 (permalink) Old Aug 22nd, 11, 06:55 AM Thread Starter
Phil McCullough
Junk yard dog; What does PM me mean? I posted a reply with my e mail address on this site, should I have posted otherwise?? hipirn
hipirn is offline
post #5 of 7 (permalink) Old Aug 22nd, 11, 05:48 PM
It means "Private Message". If you left click once on a user's name a menu pops up. Choose "Send Private Message" and then you can communicate w/o everyone on the entire internet having access to your conversation.
BPOS is offline
post #6 of 7 (permalink) Old Aug 22nd, 11, 08:58 PM
The “junk yard dog” is what I call my car. When I brought it home it was a non rolling shell that had been in Mexico. It had been customized with a fire ax, wrecked, burnt, striped, gutted, used for target practice, and left for dead. Over the last 20 years I’ve been putting it back together with mostly used ( junkyard) parts, some swap meet parts and now stuff from epay, craigs list, and reproduction that wasn’t available 20 years ago. It was also titled to a junkyard in San Antonio. I thought the name fit.
Ron
The “
Geezer is offline
post #7 of 7 (permalink) Old Aug 23rd, 11, 05:45 AM
Rick
Camaro67_rcl's Avatar
Send a message via Yahoo to Camaro67_rcl
Go to http://www.rclabbe.com/rswiring/rswiring.pdf for original wiring
Rick
67 RS/SS 355, Autogear M21 (w/Overdrive), 8.5w/3.42
Camaro67_rcl is offline
