fuel to rich....burning eyes?? - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 31st, 01, 05:25 PM
rogleete
Guest
Posts: n/a
would you say i'm running to rich if the exaust from the back of the car will burn the hell outta your eyes???? i forgot which way you turn the mixture screws on a holley vac sec to lean it some...i think its way rich
post #2 of 5 (permalink) Old Nov 1st, 01, 01:16 AM
Bruno
Lightbulb
Depending on the size of your cam, you might be having the idle screw way too much in to get a decent idle. There is a section in the Holley web page concernig this. In my case, I had to open the rears a little bit by way of a small screw in the secondaries linkage. That way I got more air in the mixture at idle/more RPMs and it let me unscrew the idle screw enough to solve the same problem. For the mixture screws I used a vacuum gauge to look for max vac. No more burning eyes for me and the fuel consuption decreased. Good luck.
Our affair with Camaros is a live sentence without the possibility of parole. www.geocities.com/c68ss http://home.coqui.net/borench
[This message has been edited by ORENCH (edited 11-01-2001).]
ORENCH is offline
post #3 of 5 (permalink) Old Nov 1st, 01, 03:12 AM
john
If you are running a Holley carb, another thing you may want to check would be for a blown power valve. Had a similar problem several years ago and no amount of adjustment would help until I replaced the valve. Hope this helps.
john
if it ain't broke fis it 'till it is
fujimook is offline
post #4 of 5 (permalink) Old Nov 1st, 01, 06:55 AM
fujimook-
Love your motto - "if it ain't broke..."
Huck
355 SBC powered '87 Chrysler Conquest TSi - 10.3:1, Vortec heads, XE 268H cam, HEI, eq. length shorties, Performer RPM intake, 750 Edelbrock (1407), T-5 and 3.54:1 posi indep. rear
Huck is offline
post #5 of 5 (permalink) Old Nov 1st, 01, 09:00 AM
john
Thanks! I wish it only a motto! Now if I can only learn to spell "fix" I'll be all set
john
fujimook is offline
