1989 RS ecm trouble - Team Camaro Tech
post #1 of 12 (permalink) Old Jun 18th, 03, 05:21 PM Thread Starter
Red face
HELP!!!!!
I'm pulling code 52 out of the ecm.
I've replaced the ecm and prom chip and it's still driving terrible.
What do I do?????
DOzER is offline
post #2 of 12 (permalink) Old Jun 18th, 03, 05:29 PM
Greetings DOzER,
If You are still getting a code 52 after replacing the ECM and chip, you might start checking to make sure that all the wires are firmly seated in the ECM connector and that none of them are damaged or bare.
[img]graemlins/beers.gif[/img]
The Trickster!!!!!!!!!!!!!!
trickster is offline
post #3 of 12 (permalink) Old Jun 18th, 03, 05:31 PM Thread Starter
Okay...I'll try that.
I've also read something about a Calpack...is that the same as the prom?
DOzER is offline
post #4 of 12 (permalink) Old Jun 18th, 03, 05:37 PM Thread Starter
p.s.
The mechanic I originally took it to had no clue what the problem was!
DOzER is offline
post #5 of 12 (permalink) Old Jun 18th, 03, 05:56 PM
Greetings DOzER,
Yes, the calpac is the same as the prom chip, they changed the name on it to make it sound more technical and confuse us poor shade tree mechanics. As for the mechanic you took it to not having a clue, unfortunately I have found this to be quite common a lot of times. This is not to say there aren't a lot of good mechanics out there. I have just found that a lot of places want good mechanics but are unwilling to pay them what they are worth.
The Trickster!!!!!!!!!!!!!!!!
post #6 of 12 (permalink) Old Jun 18th, 03, 06:08 PM Thread Starter
Angry
I guess I wouldn't call him a bad mechanic. He did a lot of free work to try and find out what the problem was. After cutting the catalytic converter off and welding it back in place...he pretty much threw up his hands and said it was the computer. I'll take your advice and check the wires...if it's not that...than I don't know what to do!
DOzER is offline
post #7 of 12 (permalink) Old Jun 18th, 03, 08:36 PM
How about a ground problem? Is there some fat black ground wire that grounds the whole unit? I would check that out. Just toss'n that out there. I have not delt with this type stuff but I do nkow elevtronics a little and connectors can get corroded. May need to shine them up a little. Thoughts?
kf6myv is offline
post #8 of 12 (permalink) Old Jun 19th, 03, 11:33 AM Thread Starter
Angry
I'm going to replace the prom chip again with another new one...maybe another computer. It could be I just got some faulty ones. The parts guy I talked to said that PROM's don't normally go bad...but who knows. There are only two harnesses that plug into the computer and both look to be in great shape. When I drive it it runs great for awhile, maybe 10 miles, then begins to jerk when shifting into third and loses almost all power. I then shut the ignition off and it runs fine for awhile. [img]graemlins/clonk.gif[/img]
DOzER is offline
post #9 of 12 (permalink) Old Jun 19th, 03, 03:30 PM Thread Starter
Unhappy
I just read something about "idle air control valve" on the 2.8 and 3.1 engines being faulty. Could this be my problem??? I am pulling code 52 from my ECM, however, after reading this article, it sounds alot like my problem. It drives great for awhile, than like that it stalls or loses power. I pull over and shut the key off, start it back up, and it runs fine again. I'm about to throw a lit flare into her....HEEEELP!!!
DOzER is offline
post #10 of 12 (permalink) Old Jun 20th, 03, 03:28 PM Thread Starter
Lightbulb
Okay guys, check this out and tell me what you think...I pulled this off of another website..."The Calpak is that other, smaller, chip next to the eprom. The dealer has them. It contains part of the fuel control code.
1987 Chevy S-10 Blazer with 2.8L PART GM# 16051459
CODE 52
Trouble Code 52 indicates that the ECM sensed a fault with the CALPACK. The CALPACK is a plug-in module separate from the PROM, that contains preset calibrations used by the system during "limp home" (backup) mode. The ECM continuously checks for its presence while power is applied.
The conditions for setting this code are:
the ECM does not sense the CALPACK
Typical causes for this code include:
1) Incorrectly installed CALPACK module
2) Incorrect CALPACK module for this vehicle
3) Defective or incorrectly inserted PROM
4) Defective ECM
5) Missing, as in swapping computers and swapping the eprom but forgetting to swap calpak also!
When I got the re-manufactured ecm from NAPA...I replaced the PROM but they said nothing about a CALPAK!
DOzER is offline
post #11 of 12 (permalink) Old Jun 21st, 03, 03:19 AM
[img]graemlins/thumbsup.gif[/img] That sounds about right DOzER, good job on your search and good luck with your problem. [img]graemlins/hurray.gif[/img] [img]graemlins/beers.gif[/img]
The Trickster!!!!!!!!!!!!!!!!!!
post #12 of 12 (permalink) Old Jun 23rd, 03, 01:02 PM Thread Starter
Angry
Well...this morning I looked inside the computer...and sure enough, right next to the prom chip is a smaller terminal that accepts...you guessed it...the calpack chip. I ordered a new one today and hopefully after installing it my troubles will go away. I'll keep y'all updated!!! [img]graemlins/clonk.gif[/img]
DOzER is offline
