distributor - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 22nd, 03, 03:56 AM Thread Starter
hello, i havent timed my engine yet, but have a 400 with hei, comp 268 cam, and performer rpm manifold. it hs to be retarded quite a bit to start up againwhen hot, i had a computer hei in it before, and would start fine when hot when advanced alot and would run trong and be responsive, if i advance thi ne, it barely cranks over when hot, mean just a hair turn, and it won. it run vry strong when advanced but wont crank over good. is there something wrong with the advance inside my distributor?
mylittle307 is offline
post #2 of 3 (permalink) Old Mar 22nd, 03, 04:21 AM
Are you running vacuum advance?
-dnult
dnult is offline
post #3 of 3 (permalink) Old Mar 22nd, 03, 10:32 AM
Conductivity of the wires is reduces when hot. If you are heating the starter up with headers or anything else your cranking power will reduce. There are shields available for keeping heat away from starters. Simple ya?
Snatchin'gears is offline
