seized wrist pins - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 10th, 01, 10:05 AM Thread Starter
Angry
Upon firing up a newly assembled engine, the engine stopped abruptly after only 2 seconds of run time. The engine would not turn over after that. I opened the motor and found all 8 pistons would not rotate on the wrist pins. I had to smack the rods with a hammer just so that I could remove them from the block! The crank appears fine, no wear found with the bearings or cylinder walls. The pistons rotated freely when I first assembled the engine. Any ideas what might have happened? Thanks!
69 Cadmaro is offline
post #2 of 6 (permalink) Old Jan 10th, 01, 12:34 PM
Don't take this wrong but did you apply any oil to the pins when you assembled the motor? Did you pre-lube the motor prior to initial start-up? If the pistons moved freely prior to start-up it sounds like a lack of lubrication.
onemorecamaro is offline
post #3 of 6 (permalink) Old Jan 11th, 01, 02:20 PM
Bill
69,
I have to agree with John, except that I have seen one case of not enough pin clearance from the factory on a set of TRW forged pistons. The locked up after about 10 minutes just like yours. Did you install the pistons on the rods ?? If so how did you do it. The only correct way is to use a rod heater to heat up the end of the rods so that they will expand and the pin will slide through. What I always do before the rods cool off totally is to apply a good assembly lube (I use Melling cam lube) to the pins. The heat tends to suck it into the pin bore...sort of like sweat soldering plumbing pipe. We do this on every set of pistons we install and have never had a failure. If you had a machine shop install the pistons, they probably would have noticed it if the pins were tight in the pistons. The pins only get lubricated by splashing oil when they first start, so it is very important to lube them properly when assembling.
Hopefully all it hurt was the pistons and pins.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 6 (permalink) Old Jan 12th, 01, 11:04 AM
Kevin
KevinW's Avatar
Wink
Does this mean that, no 'E' in Camaro has to change his ID to no 'D' in Camaro
Sorry, I just had to.
KevinW is offline
post #5 of 6 (permalink) Old Jan 17th, 01, 10:35 AM
Cool
no thats the new caddilac (not catalitic)converter replacement for the camEro
heheheheh
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
post #6 of 6 (permalink) Old Jan 17th, 01, 12:57 PM
LOL, God I love this place.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
